The gas analysers have an inbuilt database, which is why you have to input the engine number of the vehicle at the start of the emissions test (for vehicles from '92 onwards). If the engine is listed in that database, then surely it should set the gas analyser to test to the original specification of the engine? An MOT regulation cannot impose retrospective requirements upon a vehicle (cannot require a lower CO2 reading than original specification). If the engine number is not listed within the database, then the tester must carry out a non-cat test, no???
With that engine number, it should be tested as a non-cat car, as the database should tell them that the pass/fail criteria are a CO2 of <3.5% and a HC of <1200 parts per million, surely???
MOT testers best judgement
