Steering wheel removal - socket size?
#16
Posted 21 December 2006 - 07:00 PM
#17
Posted 22 December 2006 - 12:36 AM
For the amount of times I change my wheel (Only once when I fitted a Moto-lita), I used a socket a little bit too large, but not to the extent where it would damage the nut.
I know thats not ideal practise, and of course having the exact size socket is always better of course!
Whatever nut size, its always a good idea to grease the splines (not taper), as this will aid removal in the future. New shakeproof washer under the nut is a must in my opinion.
I hope u like my wheel as shown attached!
#18
Posted 27 December 2006 - 12:06 AM
jammy basturd:
Don't think it belonged to Binge. Not an automatic.
#19
Posted 27 December 2006 - 11:21 AM
Could be a fake nut I suppose.
Or is your car a twin-point? I don't think that's been asked has it? A twin point will have a different nut as it's got the column from an MGF basically.
#20
Posted 27 December 2006 - 09:43 PM
#21
Posted 27 December 2006 - 10:04 PM
OE steering wheels can be removed with a puller as they have dimples in the back for the legs to engage in. Leave the nut on but loose so there is a couple of mm gap between it and the wheel (having removed the lockwasher first) and pull or use a puller, hit the rear with a hammer, jiggle it or do what ever you can. You are leaving the nut on so you don't break your own nose when the taper releases (many people have done that) but don't leave it on by just one thread or the impact with the nut could damage the threads and re-fitting will be hard. This is a hard little taper to seperate but eventually they all come undone. Try going out to your Mini in the morning after a really cold night, heat the wheel hub (avoiding the shaft if possible) with a hairdryer for a few minutes and then give it a pull. Don't use a blowtorch or paint stripper or anything silly like that!
Oh, and don't use metric tools on imperial fixings (pet hate #4).
