1984 Mayfair rebuild
#91
Posted 24 September 2007 - 10:01 PM
#92
Posted 24 September 2007 - 11:13 PM
Jai
#93
Posted 27 September 2007 - 07:21 PM
what website did you do your paint design on? im sure ive been on it before but i cant remember it.
good luck with the mini. keep going. then you can paint it!!
cheers
#94
Posted 27 September 2007 - 09:21 PM
#95
Posted 02 October 2007 - 12:52 PM
Can't remember at the min. I got the line drawing from that Mini design site and just used MS paint to change the colours.
. . . Should keep it solid for a while.
FOR A WHILE! You mean I will have to do this again
Thanks for the advice folks. . .
Edited by gavfoz, 04 October 2007 - 07:42 PM.
#96
Posted 02 October 2007 - 08:45 PM
Its a mini - what else do you expect?FOR A WHILE! You mean I will have to this again
#97
Posted 07 October 2007 - 03:05 PM
Moving on. I decided to remove the engine from the subframe. Being on my own I need to remove enough kit so I could lift it on my own.
So:
Sadly I can feel a little lip at the top of the piston throw. by the way, a complete Mini engine novice here, should the cylinders not be completely round?
CAM4180 (whatever that means) head. The valves are so titchy tiny! Milk bottle tops are bigger!
Jobs a good 'un. Only took three hours, no bolts sheered and I only needed about three different socket sizes. The roll pin in the gear linkage was a fag but other than that an easy job.
Edited by gavfoz, 21 December 2007 - 04:23 PM.
#98
Posted 07 October 2007 - 09:14 PM
Gav
#99
Posted 11 October 2007 - 05:54 PM
#100
Posted 16 October 2007 - 03:41 PM
Clutch and flywheel removed. Took some force that and it weights a ton.
One side cover removed. Everything looks pretty oil stained. At this point I tipped the engine forward again only to find out I had never drained the oil when I removed the lump all those months ago. D'oh. Good job I used a drip tray!
Timing cover removed. Plenty of slack in the chain.
At this point I realised to remove the timing gears you need to stop the crank spinning by putting a screw driver through the starter hole into the flywheel. Perhaps I should at least read the Haynes and not just look at the exploded diagrams.
Afew 3/8ths bolts later (one had to have a slot cut in the head and impact driven to loosen) and the two parts fell away from each other.
Crank is very hard to rotate by hand. A fair bit of play in the botom of the con-rods. Cam looks nice, shiny and worn though.
Gearbox looks plenty nice enough though. A few cogs are marked and missing a few tiny bits but not so bad as I was expecting. Speedo drive is busted as it does not spin the cable
Plenty of work to do then. . .
#101
Posted 19 October 2007 - 08:05 PM
We are going low chaps. . .thanks to Custom Minis Ltd for these
Edited by gavfoz, 27 October 2007 - 12:51 PM.
#102
Posted 19 October 2007 - 08:06 PM
Anyway, I also got a pair of works dashboard pieces that I think I will get flocked or air brushed. . .
Edited by gavfoz, 19 October 2007 - 08:07 PM.
#103
Posted 20 October 2007 - 12:02 PM
#104
Posted 20 October 2007 - 04:20 PM
#105
Posted 22 October 2007 - 07:03 PM
Ordered some more C**p from Mini Spares last night. Most of the stuff is hub related. It seems silly to me to do a bare shell rebuild and not replace relatively cheap consumable items such as swivel pins, gaiters, grease nipples and the like. It will be much more hassle in the future to replace them than now whilst the thing is scattered across the garage block.
Also ordered some special brake lines for Fiesta caliper/Mini subframe conversion I am doing from a forum member. I also bought a dizzy blanking plug and some machined down discs to fit my new brake set-up from MRA minis. If I could just get the bloody big nut off the end of those CV's I would be well away and could probably build up both subframes next weekend. Not even the usually triumphant combination of blow lamp/impact driver/large lump hammer has worked. I can sense the manky chisel and mallet or the Dremel coming into play yet. . .
So, adjustable GAZ dampers, Hi-Los on new doughnuts all round, adjustable tie-bars, negative camber rear brackets, fixed negative camber bottom arms, Cooper S spec rear drums and with the Fiesta Mk2 disc's up front thats "stopping" and "bouncing" catered for. Just got "go", "weather protection" and "shinny" to go.
"Go" is easy enough and is one thing I quiet enjoy - messing about with oily bits. I guess I should of took Automotive and not Civil Engineering. . .
"Weather protection" is slightly harder. Cutting more holes and welding in real metal. It's a tedious monster of a job. Dare I say it but I may start looking for another donor vehicle with a good shell. Winter's coming = less outdoor working hours.
"Shinny" - That'll be another order to Mini Spares then
TTFN!
Gav
