But will that work? Because when i plugged my dvd player directly into my amp's aux ports, i had no control over my volume control and i burnt out alot of the wire for my DVD plater.
I honostly dont know! i will test it with my cheapo mp3 player first. dont want to fry my iPod
ok this is my first post on this forum, love minis, but i aint a noob wen it comes to sound...
i can assure you that your ipod WILL NOT work without a headunit...
ok here is why:
firstly, you wouldn't be able to turn on you amp - there isn't a remote turn on wire when you use a ipod, thus your amp won't switch on with your ipod...
secondly, the signal voltage that comes out of your ipod is waaaay too small for the amplifier to recreate...remember that all HU's have a built in pre-amp that boosts the signal so that the amp can easily pick up the sound coming in...
thus although you can connect the ipod to the amp aux connections, the music that plays (if you can turn on your amp) would be soft even at max volume....
thus to cuts this long explanation short, an ipod needs a HU with aux input or a pre amp...
hope it helps
