The clonking!
Posted 29 January 2007 - 10:41 PM
Well from that thread. I had a clonk. Fitted new ball joint as they were loose. ... .. Still have a clonking noise. Only happens over bumps. I've read that I can check for ... either CV wear or pot wear by driving full lock and listening for noise.
So I'm gonna go do that now. Any other suggestions to solve my clunking conundrum?
....stone me. I spelt conundrum right 1st time. WOOT!
Posted 29 January 2007 - 10:44 PM
Posted 29 January 2007 - 10:47 PM
......hmmm.......they are 25 years old.
edit
drove in a little circle and no clonk. Bumps tho I still get clonks.
Edited by Big_Adam, 29 January 2007 - 11:19 PM.
Posted 30 January 2007 - 01:09 AM
Posted 30 January 2007 - 01:50 AM
someone over here had knocking due to a couple worn suframe bushes, check them too
Posted 30 January 2007 - 08:27 AM
I mean it only happens at low speeds. I can bomb about at 60-70 on country road and there no clonk. Well apart from massive holes. But on regular roads at low speed (30) over manholes I get the clonk....
....that last bit sounds wrong.
Edited by Big_Adam, 30 January 2007 - 08:30 AM.
Posted 30 January 2007 - 02:01 PM
Clonk is still here. Check the subframe tower mounts were still tight, they are. Check the bushes over (bottom subframe ones. the ones that connect the subframe near your feet) they look all good. Bounced on El Gordo, no clonk.
......this is getting annoying. Any other ideas chaps?
edit
couldn't be the rack could it. I jacked up El Gordo and gave it a wiggle and there is a tiny wee clonk when you pull the wheel left to right.
Racks only a year old tho.
Edited by Big_Adam, 30 January 2007 - 02:14 PM.
Posted 30 January 2007 - 02:46 PM
Posted 30 January 2007 - 02:48 PM
Just been to my local nice mechanic place and he suggested the following.
a) Could be worn cups on the suspension,
I said probly not as the car would drop. He say..."hmm good point"
B) Suggested taking damper off.
This is what I'm now going to try.
Edited by Big_Adam, 30 January 2007 - 02:48 PM.
Posted 30 January 2007 - 04:12 PM
not the damper. Next idea anyone?
Posted 30 January 2007 - 04:31 PM
Dependant on the answer to the above question would steering colomn bushes make a 'clonking' when knackered?
Posted 30 January 2007 - 04:37 PM
edit
been recomended new bushes for the arms. Good idea?
Edited by Big_Adam, 30 January 2007 - 04:56 PM.
Posted 30 January 2007 - 06:25 PM
Posted 30 January 2007 - 06:57 PM
Posted 30 January 2007 - 07:07 PM
As for the bushes, mini spares do 3 or 4, there rubber, poly for weird gemonetry, poly top hat ones.
bugger me it's confusing.
