Painting MDF
Posted 04 March 2007 - 02:27 PM
Posted 04 March 2007 - 02:41 PM
Mdf tends to soak up the paint alot.. so u have to keep coating it..
Posted 04 March 2007 - 02:43 PM
Edited by Rodders, 04 March 2007 - 02:44 PM.
Posted 04 March 2007 - 03:19 PM
http://www.internati...mp;surfaceid=48
Edited by Steve@RetroDash, 04 March 2007 - 03:20 PM.
Posted 04 March 2007 - 03:34 PM
Posted 04 March 2007 - 03:54 PM
Any reactions?
Posted 04 March 2007 - 04:06 PM
have a practice on a scrap piece. you can get it as smooth as glass but it depends on the time you have available. Use wet and dry between coats of colour.
Posted 04 March 2007 - 04:16 PM
Time is not a problem, i just wondered if MDF needed a sealer first.
Posted 04 March 2007 - 04:28 PM
its to do a boot liner kit in same car colour.
Ideally yes but in practice probably not. If you have the budget then use mdf primer as its quicker to get the next layer of paint on but you can still get a good finish without it.
you could always use shellac as a base coat, I use this on furniture to seal the wood before a finish is applied. This stops any contaminants from surfacing through the finish.
http://www.axminster...amp;src=froogle
http://www.axminster...ealer-21180.htm
http://www.axminster...ealer-19767.htm
Edited by Steve@RetroDash, 04 March 2007 - 04:32 PM.
Posted 04 March 2007 - 05:27 PM
Posted 09 March 2007 - 12:48 PM
Whatever coating you end up using, rememeber to wet & dry it to get a smooth finish before you start painting.
Posted 09 March 2007 - 11:06 PM
Posted 27 August 2007 - 02:25 PM
I then applied MDF primer and flatted off with 240 grit.
Finally a high build filler primer from Halfords was used before flatting with 600 grade wet and dry. You might need a different colour primer over the filler; depending on what you're top coat requires. One coat of cheapo primer is more economical in the long run than several extra coats of body colour.
Don't laugh at my crappy speaker wiring.
Edited by hlynur, 27 August 2007 - 02:26 PM.
Posted 29 August 2007 - 10:39 AM
