Minispares Stage 1 kit std 1300
Posted 13 March 2007 - 01:00 AM
cheers very much, sorry if thats not enough info
Posted 13 March 2007 - 09:08 AM
Posted 13 March 2007 - 09:22 AM
Its there to prevent the carb icing up, the alloy inlet manifolds are much better than the std cast items at preventing thermal transfer from the block (and exhaust manifold where they are originally one item).
Posted 13 March 2007 - 09:41 AM
Posted 13 March 2007 - 09:49 AM
You NEED to connect that pipe to your heater hose.
okay cheers fellas, one more question...
the heater hose looks to me to be too big to fit, and also doesn't go very near the manifold so seem like it would taake a fair bit of extension to get to it... there are a few pipes that sit straight across the manifold, but they seem to be emission pipes... what exactly do i need to connect
cheers
Posted 13 March 2007 - 10:14 AM
Heater hose is cheap as chips as well, costs £4 a metre or something like that
Day101, quite a few people dont connect it up and you may not notice anything depending on how and when you drive your car. It is there for a reason though, some peeps have even reported better fuel consumption after connecting it (thats a good enough reason for most!).
Posted 13 March 2007 - 10:18 AM
You need to connect the bit that comes from the water take off and flows through the bulkhead into the heater matrix. IIRC the heater take off is on the thermostat on a 1275 head ?
thanks a lot! when i said one more question i lied, i have another, sorry...
just found the gas sampling pipe attached the exhaust manifold...something to do with the fact i have a cat? doesn't seem to be a simple way to connect that to the new manifold...
Posted 13 March 2007 - 10:28 AM
Posted 13 March 2007 - 10:30 AM
You don't NEED to connect this, and in fact I have NEVER connected it... Carb icing occurs in the carb not the manifold, and the carb is isolated (thermally) from the inlet by the plastic spacer block...
It's there for those which use it in colder climates ( ie scandinavia etc )
Posted 13 March 2007 - 10:54 AM
Posted 13 March 2007 - 11:00 AM
I'm gonna have to disagree with you on this GW, mine runs better with it connected !
As guessworks says, the carb is isolated. Had carb icing on my El Gordo with the K&N cone filter jobbie. If you want to stop carb icing then the hot air feed need to be connected to the airbox.
Posted 13 March 2007 - 11:03 AM
Posted 13 March 2007 - 11:08 AM
[attachment=29017:DSCN1508.JPG]
El Gordo's 998 engine (finished in yellow, is very nice) note the CONNECTED alloy manifold. I HAVE had carb icing with this set-up.
Please explain.
edit
....man I need to clean up them master cylinders.
Edited by Big_Adam, 13 March 2007 - 11:14 AM.
Posted 13 March 2007 - 02:30 PM
http://en.wikipedia....arburetor_icing
I have some more info at home on it as well which I will dig out, I am not making this up ! The manifold is heated to help prevent carb icing !
Edit; I like the yellow
Edited by Jimmyarm, 13 March 2007 - 02:35 PM.
