Flubber!
779 replies to this topic
#571 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
  • Local Club: Shatrats.com
Posted 03 January 2008 - 06:30 PM
New fuel pump bits arrived today :dontgetit:
Along with a HIF44 rebuild kit.
Going to rebuild a HIF44 over the next few days, fit my fuel pump possablity the weekend...
Hopefully, this will narrow down what the actual problem to why Flubber is refusing to start properly...
#572 MINIMON
MINIMON
  • 454 posts
Posted 04 January 2008 - 03:25 PM
god luck with it! surely there cant be much more that you havent checked/swopped! it will run one day though!
#573 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 24 January 2008 - 08:24 PM
Well carb is rebuilt, and I have a free weekend next weekend...
I am going to see if I can get the old boy going properly now. Show season is apon us!
Watch this space ;D
Jobs I need to do;
  • Chop out grille
  • remove old dizzy and check dizzy timing
  • Fit new Aldon Dizzy
  • Fit new rebuilt carb
  • Replumb in Oil cooler (and attach to inner wing)
  • Check all the front wiring
  • Remove rear wiring loom
  • Replace rear loom with the new loom
  • Fit new fuel pump
  • Fit Fuel filter/reg
  • get Headlamps working
#574 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 24 January 2008 - 11:08 PM
no dont chop teh grill out!! its a van thing.
also dont you need to put brakes on it? i thought you stole them for voodoo?
#575 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 24 January 2008 - 11:12 PM
Nah never got that far Boo.
Brakes are all still intact on the Van. Only thing I do need to get, is tyres (which I have) ;D
I am chopping the grille out, so I can have a removable pressed steel jobbie - you'll see, once the grille is fitted, you won't notice.
#576 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 28 January 2008 - 09:15 PM
Just an update to bring the spec up to date...
Orignally a 850, then it was a 998, and now its currently a 1380.
I've owned it since March, and the current spec sheet is thus...
  • Rear subframe complete refurbished
  • All nuts and bolts renewed
  • New rear raduis arms
  • New 1.5* Neg camber brackets
  • New cones
  • New Hi-los
  • New handbrake cable
  • New wheel bearings
  • New "Complete" rear drum brakes
  • New Adjustable GAZ Shocks
  • New bushes
  • New Braided brake hoses
  • New fuel tank & sender
  • Undersealed and painted
And the front has had a simuar treatment...
  • Refurbished front subframe
  • New brake master cylinder
  • New Clutch Master Cylinder
  • New break lines
  • New braided Brakes hose
  • New cooper hoses
  • Cooper S 7.5" Calipers and disks
  • New blackstuff break pads
  • New Cones
  • New upper arms
  • New lower arms
  • Heavey duty tie rods
  • New bushes everywhere
  • New Brake light switch
  • New ball joints
  • New adjustable GAZ shocks
  • New Master brake cylinder
  • New Clutch Master cylinder
  • All nuts n bolts renewed
This was also fitted along with my 1380, which I've built...
  • 1380cc
  • Stg4 Rob Walker head
  • Twin HS4 1.5" SU's on a Maniflow inlet
  • 1.5:1 Roller Rockers (Swiftune)
  • SW5-07 Camshaft
  • New followers
  • New pushrods
  • New pistons (73.5mm Powerman 7cc dished)
  • Balanced and lightened A+ con-rods
  • New 1275 A+ Crankshaft
  • New bearings - inc cam bearings
  • New Veriner dupplex timing chain
  • Pre-A+ transfer gears
  • Rebuilt and strenthened GT gearbox
  • Centre oil pickup pipe
  • Xpin differantal
  • 3.1 Final Drive
  • Lightened and balance billet Flywheel
  • New orange clutch diaphram
  • Rally/race clutch plate
  • New Aldon Yellow electronically converted dissy
  • New 10row oil cooler
  • New oil temostat
  • Converted to pre-engaged starter
  • New super cool 2core rad
  • New 6 blade "hot" fan
  • New large impeller water pump
  • New Sylicone hoses (ALL)
  • New core plugs
  • New oil ways
  • New fuel pump
  • New fuel filter/regulater
Other bits I've done to improve it...
Momo Leather steering wheel
Steering dropped
Added AUX dials... Vac gauges, Oil pressure, Oil temp, rev counter, Water temp, Volts.
#577 camp freddy
camp freddy
  • 3,696 posts
Posted 28 January 2008 - 09:42 PM
  • New cones
  • New Hi-los
  • New bushes
  • New break lines
  • New cooper hoses
  • New Cones
  • New upper arms
  • New lower arms
  • New ball joints
  • 1380cc
  • SW5-07 Camshaft
  • New followers
  • New pushrods
  • Xpin differantal
  • 3.1 Final Drive
  • New oil temostat
  • New core plugs
  • New oil ways
  • New fuel pump
Steering dropped
Mart, did you see the leather Mamba high back bucket seats for a measley
£100 the pair at the show, they were gorgeus :kiss:
#578 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 28 January 2008 - 09:52 PM
No :kiss:!!!
They would of been peeeerrrrrfffeeecctt!!
Once the enigne is going, I am starting the inside... the theme - Black, Leather, and brushed Aliminum!
Just a smart, stylish, high end "posh" car look. With a decent ICE system, padded rear floor...
#579 camp freddy
camp freddy
  • 3,696 posts
Posted 28 January 2008 - 10:03 PM
No :kiss:!!!
If i had an extra ton they would have come home with meeeeeeeeeeeeeee!!!
they were on the stand in the middle where the wheels were next to the
minisport stand.
#580 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 08 February 2008 - 10:53 PM
Well will this weekend see the Van running? Who knows... but...
Fuel Pump - Check
Fuel pump spacer - Check
New bolts - Check
New Dizzy - Check
Battary Charged - Check
Time to prepare myself for a few more battle wounds....
#581 camp freddy
camp freddy
  • 3,696 posts
Posted 08 February 2008 - 11:01 PM
you forgot one thing......
fuel!!!!!!!
Edited by camp freddy, 08 February 2008 - 11:03 PM.
#582 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 08 February 2008 - 11:03 PM
fuel!!!!!!!
Got fuel :D
Well... half a tank thats been sat there since September, do think it'll be ok?
#583 camp freddy
camp freddy
  • 3,696 posts
Posted 08 February 2008 - 11:05 PM
fuel!!!!!!!
Got fuel :shy:
top it up with methanol, if it's going to fire up at all it will on that!! :D
#584 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 08 February 2008 - 11:08 PM
Where can i get Methanol from? :D
It'll certainly sound nice if it does go :shy:
#585 camp freddy
camp freddy
  • 3,696 posts
Posted 08 February 2008 - 11:16 PM
hope you get it sorted Mart.
