my ongoing turbo clubby project
315 replies to this topic
#241 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 23 October 2015 - 09:16 PM
Once again progress has been a bit slow due to work, getting pneumonia and playing around with old Corollas but it's had a kick up the arse of late and things are happening at last.
Engine build turned out to be more complex than I imagined. Plan was to re use most of it and just build a new bottom end.
I bought a set of +20 18cc forged Omega's, then worked out my compression with the 28.5cc head I had and it came in around 7:1, way too low!
Sold the head and have got a new one on order with much smaller chambers to get my compression somewhere much more sensible.
Sent my 1275 block off to be soda blasted along with a few other parts (not the gearbox, it works so I'm not stripping it out and distubing things, that'll just get cleaned and painted)
4C1B74AE-ECB2-492C-8F12-C32A1C1FEB17_zps
Then it got sent to the machine shop for the usual stuff, rebore, 11 stud, centre strap, tapped oil galleries, cam bearings etc.
Also ordered a crank and gave them my flywheel and crank damper to get the whole rotating assembly balanced.
While that was all being done I got on with making up the few solid brake lines I needed to do. Ordered a straightening tool, by far the most useful thing I've used in a while, I hate wiggly brake pipes!
6F9A5AE2-A815-4A2D-9BAD-02A96A15C14B_zps
Got this little lot back and a nice parcel from John at Specialist Components.
36D5003C-0C75-4877-80E5-6C14A3507EE4_zps
ADF5C413-367C-4B89-AE94-FAF3CB2E5927_zps
Came home from working away all week to a delivery from MED as I needed the shorter gudgeon pins and circlips to suit my new rods, also needed new timing gear as my old doweled one was a pain in the arse.
0984A899-1B0D-4B97-86BD-7EEB38981BD6_zps
That was last night and the pile I was greeted with so I got straight on with building the bottom end to check some tolerences.
2285C995-F5BC-498D-8DF9-C35833D4BB15_zps
AC2D1D3B-1445-4821-9DDE-87FB78066680_zps
658FCEED-EF68-4836-B75F-201389706273_zps
3CE7588E-C5ED-45DC-A6BB-E1D0403B0674_zps
Next chance I get I can check the crank end float and also measure how much the block needs decking.
Only other engine parts I'm waiting on are the cam and head now, and I need to decide which oil pump to run and get that ordered.
All in all a pretty successful update and another expensive part out of the way, just the paint job left to save for.
#242 Pauly
Pauly
  • 4,213 posts
Posted 24 October 2015 - 11:35 PM
Christ dude I thought you'd been quiet of late. Glad to hear your back on the mend!
It's looking good though
#243 José Cardoso
José Cardoso
    Just On Tickover
  • 6 posts
Posted 25 October 2015 - 02:53 AM
Sadly I think your crankshaft do not go last for long time in a turbo engine...
See the next topic to see what appened in a crank like you have in a turbo engine:
http://www.theminifo...d-engine/page-2
Edited by José Cardoso, 29 October 2015 - 12:29 AM.
#244 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 26 October 2015 - 08:23 PM
I guess we shall find out!
That's the first one I've seen snapped out of how many out there? Sometimes you're just unlucky and stuff breaks
#245 mini13
mini13
  • 3,811 posts
Posted 27 October 2015 - 09:22 AM
that snapped crank wasnt in a turbo lump so isnt comparable.
despite what is written it IS rpm that kills cranks, unless of course they run in a resonant patch of rpm...
generally turbo lumps will only see 7k max, and the extra forces from combustion pressure actually oppose the forces from rpm.
#246 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 27 October 2015 - 06:46 PM
Did I mention I was building this one for 8k+ rpm?
Expecting slightly more frequent rebuilds than my last one though..
#247 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 22 December 2015 - 10:46 PM
Pre Christmas update :)
Managed to get hold of another twin bolt subframe to hack up, moved the top arm mounts to give a nicer angle on the top ball joint with how low I want to run the car.
4D08ABEB-D619-42B0-8AE7-E807AD9F46EA_zps
Need to adjust the shock mounts again now as the top arm move has pushed the bottom of the coilover into the wheel, should be a quick fix once I get the subby back on as it's off being shotblasted.
E69EA7D9-8314-4972-9399-89530C4F9A8A_zps
Engine build is progressing well, just the head that i'm waiting now and a minispares order tomorrow.
Bought the dsn timing cover kit off johnny because I'm a tart and it looks pretty. Went for the one of the swifty oil pumps as the MED evolution are out of stock for the foreseable future.
Got it all timed up tonight, The MED timing kit is way better than my old doweled minispares one.
Just need the primary shim to arrive and then I'll re-check the idler and get the box /clutch etc bolted on. Will stick a spare head on for now so I can start looking at making a new downpipe and exhaust once the subby is back in.
55DB9541-B7E1-4162-9A3C-A5CA3B657193_zps
539F61BB-7EA1-4503-82C8-35D7D34BD98B_zps
571C4C31-6F66-4D23-8C53-A07D76D93C66_zps
CDCA165F-674F-437C-A49B-EA023BE1D6F2_zps
AA808B19-D471-4123-864C-0B25CA49FE23_zps
64EBA207-DB14-499A-966B-EF9778345AD9_zps
Also started stripping down my turbo as it was pretty worn, just caught it before the comp wheel started picking up on the housing
453584D3-15A3-43A2-AA9F-DA8D9192E127_zps
14D95F70-D601-4CF9-B8EE-6D348B773B10_zps
That's it for now, more to come over christmas with any luck :)
#248 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 22 December 2015 - 11:31 PM
:thumbsup:
#249 coopdog
coopdog
  • 4,506 posts
Posted 23 December 2015 - 11:26 AM
Moreeeee
#250 Jayme 1275
Jayme 1275
  • 488 posts
Posted 25 December 2015 - 11:11 AM
Looks great mate, crank looks awesome. Would love one for my 16v build, id just be scared the revs would kill it, at the end of the day though if they stand the abuse the miglia's give them they are bound to be more than up to the job.
Also neat idea to move the top arms, be interesting to see how that goes.
Look forward to seeing this done.
#251 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 28 December 2015 - 05:28 PM
Managed to get it back down on its wheels today at last.
Pretty much finished the front suspension off yesterday and finished building the engine this morning.
714F0B9D-93BE-4453-AD7F-183454937CD9_zps
97146D2D-53BD-43D3-9DD5-F9A9D4490E05_zps
D11D60F6-E46B-4228-A810-3336CE799064_zps
#252 Wupding
Wupding
  • 38 posts
Posted 28 December 2015 - 10:52 PM
.... I'm drooling
#253 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 28 December 2015 - 11:19 PM
I've gone off minis, but honestly I'd have this one in a heartbeat. Hopefully you can keep the engine bay nice and bare.
#254 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 28 December 2015 - 11:35 PM
Looks great :gimme:, what paint did you use to paint the engine?
#255 coopdog
coopdog
  • 4,506 posts
Posted 29 December 2015 - 02:19 PM
Getting exciting now
