Apparently with throttle bodies the BMW 16v head will fit under a standard round nose, but not with webers. The KAD head wont fit with webers either, not sure bout throttle bodies. The arden 8 port can be made to fit under standard bonnet, if you use amal carbs, or the short weber manifold. But most people go for the longer manifold which means the carbs hang out the front.
7 ports fit nicley under the bonnet if you're after something discreet. God knows about this MED or the Elder 8 port tho, the elder aint very commen, so its hard to find info on it. And the MED one is new
To be fair to MED, they know what they're doing. He probly means 10bhp more than whatever stage head you've got at the mo. But if he says 'minimum' i'm sure thats before he's fully worked the head, so there will be much more to come knowing MED. Plus if the rest of you're engine is all MED at the moment they should be very familiar with it so they will be able to get the very best out of it....
...It al just depends on what you want, but whatever way you look at it, tuning the a-series is expensive
*(unless you're handy with a dremel
