Carb butterfly Q
minivanman
, Apr 29 2007 06:15 PM
18 replies to this topic
Posted 29 April 2007 - 06:15 PM
I won a set of twin HIF38s on ebay the other day (£25 - uber bargain). Having a quick gander at them today I noticed a brass circle soldered onto the butterfly. I opened them up and theres this on t'other side:
I was just wondering what it is? or am I being really thick?
Posted 29 April 2007 - 08:00 PM
That would be an overdrive valve. also known as kack.
Posted 29 April 2007 - 08:23 PM
That would be OverRun
Posted 29 April 2007 - 08:29 PM
so what does it do exactly? and why is it rubbish?
Posted 29 April 2007 - 08:49 PM
Nuts, I was close tho.
"Rubber bumper MGs have carburettors fitted with overrun depression limiting valves fitted to the butterfly or throttle disc. The idea behind these valves was to clean up exhaust emissions by drawing in more air on the overrun. If the springs become weak and the valves fail to close properly an erratic tickover with a rising idle speed will result. This can be remedied by replacing the valves with new ones or by reverting the earlier specification butterflies without the overrun depression valves."
Thats what it does. It also feck the flow of the carb at full throttle something lovely.
Posted 29 April 2007 - 08:56 PM
Ta Adam. Thats exactly what they're off - a rubber bumpered MG. I did think it wouldnt do much good for the flow having two great springs in the way! so thats something else on the shopping list then! I'm going to have a bash at reconditioning these myself.
Posted 29 April 2007 - 09:00 PM
apart from the bushes in the carb it's easy (and relaxing) to do. If you want I can send you over the bit in Viards book on tweaking the carb for more flow.
Can get a hs4 to flow like a weber if you are so inclined. Their only little tweaks but they really work.
Posted 29 April 2007 - 09:01 PM
just to help you out a bit, i have them on my twin HIF44's and they run smoothly. if that helps u out a lil more??
Posted 29 April 2007 - 09:07 PM
be wary of some of these mods, as although yes on paper they give more flow, they do upset other charecteristics...
bin that throttle disc and get a solid one!
ttfn,
Dave
Posted 29 April 2007 - 09:10 PM
twin 44s? what spec engine is that?
Cheers Adam, I've already got the big yellow bible. The bushes feel ok, I'll have a closer look tomorrow. I'l just have to build an engine for them to go on when I've reconned em!
Posted 29 April 2007 - 09:30 PM
Ah, if there's a little play then a new spindle will probably remove that. Did on my Hs4.
Posted 29 April 2007 - 10:16 PM
spec's endless but all i know is them 44's make it run sweet as a nut. engines worth 5k
Posted 30 April 2007 - 09:30 AM
Still, twin 44s on a 1380 seems quite excessive!
Posted 30 April 2007 - 04:38 PM
depends on the cam to be honest dude. i know my mate could do with a pair on his 300deg cammed daily driver.
Posted 11 May 2007 - 10:44 AM
just by reading this i solved a problem on my 1275 metro engine, it was ment to have been sorted 3 days ago woops lol
