Think that might be a HIF4 - they were produced in matching pairs. The HIF38s weren't as far as I know. You might want to add a dizzy vacuum take-off too, although I know some just use a spacer with one pre-installed. Ideally though, the vacuum take-off point wants to be close to the butterfly disk.
Being 1.5 inch, the HIF4 is marginally bigger than the metric HIF38 - your gain!
Carb butterfly Q
minivanman
, Apr 29 2007 06:15 PM
18 replies to this topic
#16
Posted 12 May 2007 - 11:07 AM
#17
Posted 09 June 2007 - 12:44 PM
When I had my hif44 apart I noticed this also had over run valve, assumed it was std for cooper's, I removed mine and re soldered up the resultant orifice..
#18
Posted 09 June 2007 - 01:56 PM
Good job.
#19
Posted 10 June 2007 - 12:36 AM
to be honest i much prefer replacing the butterfly with a solid disk,
soldering up the hole where the overrun valve was is imho gives risk to it becoming 'unsoldered' and getting sucked through the engine.
