Wiper's not working
#16
Posted 12 June 2007 - 05:04 AM
#17
Posted 12 June 2007 - 06:32 AM
fog is water isnt it. when you drive through the for (mainly if its dense fog) the windscreen will have water droplets all over it and will reduce vision.Sorry. Slightly O/T, but why would the wipers help in fog anyway?
Sorry to be of no help but this confused me
#18
Posted 12 June 2007 - 08:52 AM
#19
Posted 12 June 2007 - 05:06 PM
#20
Posted 13 June 2007 - 01:37 PM
http://www.minispare....aspx?pid=32887
They have a tendency to pack up and either stop the wipers parking properly or else not work at all
Laters
Gav
ps. thanks for the Danish lol
Edited by Touche Away, 13 June 2007 - 01:57 PM.
#21
Posted 13 June 2007 - 02:06 PM
My money's on the park switch too. That's the creamy white plastic bit on the wiper motor that makes sure the wipers stop at the bottom of the screen. It just slides in so a gently prise with a screwdriver and pushing to and fro should free it. quite often they'll respond to a spot of fiddling, push the little plunger in a few times and twist the case a little bit to free it off. If you're stuck, the wipers will work without it fitted they just won't park.
Otherwise it's out with a meter or test lamp to see where the volts stop flowing - start at the motor and work back.
#22
Posted 13 June 2007 - 03:05 PM
#23
Posted 13 June 2007 - 04:22 PM
#24
Posted 13 June 2007 - 08:16 PM
So check the state of the park switch and wires on the rear of the wiper motor.
Edited by taffy1967, 13 June 2007 - 08:18 PM.
#25
Posted 19 June 2007 - 08:52 AM
You'll probably find that it is a faulty park switch (the white bit under the motor).
Laters
Gav
Funnily enough it was exactly that Some person with a chocolate toffee Danish addiction sorted it out for me on Saturday
Could also be due to the park switch or the wiring to it from the wiper motor. Perhaps the connections have come away through corrosion.
Corroded connections are fun
Edited by PinkGirly, 19 June 2007 - 08:53 AM.
#26
Posted 19 June 2007 - 09:37 AM
my heaters and wipers only work when my lights are turn on any ideas peps ???
i didn't know you still had that problem dan lol
i've had things like that in the past.
oli
