998 vs 1275????
#16
Posted 13 June 2007 - 08:29 AM
does anyone know a good source for a 1275 or can point me in the right direction???
Thanks for everyones input
cheers
#17
Posted 13 June 2007 - 09:16 AM
unless you know the history of an engine, i would not recomend sticking it in without at least checking it over internally.
therefore get a cheap motor, even if its a bit iffy or done loadsa miles, it will be ok once you've rebuilt it
#18
Posted 13 June 2007 - 09:47 AM
#19
Posted 13 June 2007 - 12:11 PM
or if I had the money a B18A2
#20
Posted 13 June 2007 - 01:28 PM
Pick up a 1275 from a metro for peanuts, budgeting for a rebuild, this way you can get a cheap motor in the first place, but end up with something you know is completely sound
Okie so metro 1275 sounds like a winner,
Im assuming the metro engine is still an A series Engine?
Again thanks for all the advice.
#21
Posted 13 June 2007 - 01:31 PM
#22
Posted 13 June 2007 - 01:37 PM
#23
Posted 13 June 2007 - 01:54 PM
What do you meaaaaaaaan!
#24
Posted 13 June 2007 - 02:11 PM
a 1275 wouldn't go back to the 998 but a mini's fun no matter what.
yer the 998's like to rev higher than the 1275, must be the shorter stroke where as the 1275
has a longer stroke. i think
#25
Posted 13 June 2007 - 06:49 PM
will standard mini mountings work??
cheers
#26
Posted 13 June 2007 - 08:11 PM
#27
Posted 13 June 2007 - 09:52 PM
#28
Posted 13 June 2007 - 10:36 PM
#29
Posted 13 June 2007 - 10:42 PM
#30
