20W50 is considered a summer oil as it very thick when cold, thats the 20W bit, its also thicker when its up to temp, thats the 50 bit. That is compared to 10W40. 10W40 is the oil I have used all the time, it causes less drag in the engine/transmission and helps reduce power losses and fuel consumption.
I always get confused by the numbers. You say 20W50 is a thicker oil than 10W40, so by my assumption, the higher the number the thicker the oil? But, you then say 20W50 is thick when cold (the 20W) and even thicker when warm (50 bit), but oil gets more runny when warm (hence why you warm the engine when doing an oil change)?
Jammy, you always find a way to twist around evry ones words and see through the real meaning
What I meant was, that when the oil is hot, the 50 is thicker than the 40. Not that its thicker than 20W grade of the oil. The winter grade is better described as cold start. So in winter when the temperature outside is -10c the 20W is thicker than the 10W at -10c, and not protecting your engine gearbox as well as the 10W. The 20W doesnt flow to the critical parts quickly.
An ideal world would have an oil that is the same viscosity whatever the temperature
