My Bendix keeps jamming
Posted 04 July 2007 - 10:32 PM
what is wrong, why is it doing it and what can I do to rectify it.
LOL, i think the starter is older than me.
Sprox
Posted 04 July 2007 - 10:49 PM
the only thing I can suggest is changing the starter for another.. or atleast replacing the bendix ?
Posted 05 July 2007 - 05:32 AM
Posted 05 July 2007 - 06:46 AM
I'm sure i heard somewhere that you're not supposed to lube the bendix, i'd have thought if it was oiled the dust from the clutch would stick to it and jam it up. might be worth trying some graphite powder instead? or just swap it if its older than gods dog
Edited by bud666, 05 July 2007 - 06:46 AM.
Posted 05 July 2007 - 06:58 AM
Posted 05 July 2007 - 07:04 AM
its something i always remember my old man telling me years ago, strange the things that stick in your mind.
Posted 05 July 2007 - 11:41 AM
Thoroughly clean the Bendix you have. I use acetone or lacquer thinner, you want something that evaporates quickly and does a good job of removing all oil and grease without leaving residue. If you have an air compressor, blow it dry when you're done.
Now I know I just said don't lube a Bendix. However, there are two schools of thought about this. The first is to run the Bendix bone dry. I prefer a second method that used to be in vogue. Spray the splines of the Bendix with with dry powdered graphite or moly powder. It won't attract the grime that binds the Bendix up and it can help a sticking Bendix retract.
Posted 05 July 2007 - 12:01 PM
Posted 05 July 2007 - 04:23 PM
Ask one of the Mini Docs... they're bound to know!!!!!
Thanks?
Posted 05 July 2007 - 05:48 PM
However, what you have to consider is that the oil is fresh, its light oil, its a brand new clutch and the flywheel housing is spotless, inside and out, there is no C**p or dust at this point in time. So, why is my bendix jamming requiring a BFH to free it off. My point being if there was no oil it would still jam solid.
I think im going to get a replacement on Saturday, thanks for the help
Posted 05 July 2007 - 06:13 PM
does some times happen at work, different starters tho
Posted 05 July 2007 - 07:15 PM
There are also several similar looking but different inertia starters. The A-H Sprite/MG-Midget have very similar but different inertia starters. I can't tell you how to distinguish one from the other but I know they use a different part number and you aren't supposed to use them interchangeably. Is there any chance you have a non-Mini starter?
Posted 05 July 2007 - 07:20 PM
Posted 05 July 2007 - 09:00 PM
surely the solenoid is on top of the starter so it should still fit with a front mount rad? sorry for going O/T
Oh my... I believe I missed the truly fundamental aspect of this. Was this originally an A+ motor with the pre-engaged starter and now your fitting the inertia type? You are now out of my league. I believe the ring gear tooth count is different on A+ and you could have a situation where the components simply cannot work together.
Were I you, I'd start a new thread and ask: "Can you use an inertia starter on an engine with a pre-engaged ring gear?"
It appears you're working with something too new for me to be of any help. Sorry if my comments mislead you.
Posted 05 July 2007 - 11:20 PM
I fitted an old inertia starter due to fitting a front mount rad, so bought the lightweight flywheel with the apropriate ring gear.
