Posted 18 August 2007 - 03:17 PM
Yeah those things are bloody brilliant but kinda expensive as they don't last long. If you are planning to strip the shell before removing the paint, I'd use nitromors, and then go over it with 80 grit sandpaper on a DA. That gets rid of everything, with a stripdisk (pictured above) you cant get into crevices, so it has it's limitations. Nitromors is horrible stuff, but works really well so long as you do a small area at a time and clean off the area with panel wipe after. Oh and always wear gloves and goggles! I got some in my eye at work, the most painful experience of my entire life!
Pete
