Ive gone for the zcars race spec vtec option with the Type-r k20a engine.
i went for the race spec kit for the big brakes, LSD and extra safety features, not to race.
There at first glance doesn't seem to be many people with this setup on here so i hope i can help people out with what i have found when fitting the kit and the differences from the Zcars builder DVD.
I dropped my donor civic engine off with zcars and they fitted it to my frame along with the LSD and Sump (part of the kit).
I started with cutting the shell as per the directions on the DVD. Then i have cut 3x4 inch holes in the firewall directly behind the front subframe mounts.
I have also had to cut the tunnel to accommodate the extra strengthening bar and the lower dash rail is removed.
The rear valence was removed. (i didnt know about the last three until the frame was half in and i had to cut around them. nightmare!)
DSC00024.JPG 648.02K 93 downloads
One of the first things i bought for this kit was a fuel pump. i got a walbro 255 from www.flat4online.co.uk for about £100.
i managed to get the two halves together with the help of some mates and the angle grinder to hand for the extra bits cutting off.
Bolting up the front frame was done as expected like the dvd as was rear to the shell.
DSCF2475.JPG 1.44MB 239 downloads
After the instructions on the dvd became irrelevant i had to just suck it and see with the rest of the build.
After installing the fuel lines and water pipes i was able to attempt the wiring loom install.
I bought the wiring loom and power-up kit from zcars and spend a good 6 hours trying to mate them to the connectors on the lights and dash switches etc.
I have yet to mount the battery as i dont own one small enough to fit under the radiator. I managed to start my engine which was a relief as it was bought from a scrap yard.
I am building the car up so that i cut / drill the shell as much as i needed, so i will take it all out and it will be as final as possible before spraying.
The car now has a mounted seat and is just waiting for 4 wheel alignment (booked in with zcars in a week or so) so that the wings can be cut further to fitting the new carbon arches.
DSC00014.JPG 451.47K 165 downloads
I have still loads to do, and so much to remove for re-fitting after the spray job....
now what colour to choose.......
Al
Edited by al_reidy, 17 January 2009 - 07:11 PM.
