hi there!
im wanting to paint these wheels if i buy them, how would i get the spokes silver and the recessed parts black?? obviously you cant mask off while powder coating..... ill get them shot blasted before i pait them.
any ideas?
thanks in advance!
Ed
How Do I Paint These Wheels?
tedmcedd
, Aug 28 2007 05:55 PM
8 replies to this topic
Posted 28 August 2007 - 05:55 PM
Posted 28 August 2007 - 06:00 PM
Well you could paint them all silver and then mask of the bits you want to be silver and then put on the black. This should work I think.
Edited by Mini 360, 28 August 2007 - 06:00 PM.
Posted 28 August 2007 - 06:02 PM
do you need special paint for alloy, surly it would flake off???
Posted 28 August 2007 - 06:27 PM
Firstly, get them sand blasted, not shot blasted, shot tends to mean the coarser grade which eats alloys! If I was doing them, I'd sand blast them, then etch the bare metal, prime them in 2k high build primer, carefully masking off the areas you want to be silver, placing the tape about a millimetre past the edge you want to be silver. Remove the masking tape and flat them down with 800 wet n dry and scotchbrite for the hard to reach corners, getting it as smooth as possible. Paint the entire wheel black, (including the parts you want to be silver). Now for the clever bit, let the paint dry COMPLETELY, and rub down the areas you want silver with 800 wet and dry, until you get down to the bare metal. Flat down the metal further with 1500 wet n dry. This way you'll get a very crisp clean edge between the metal and the black areas. Clean the whole wheel thoroughly with degreaser and lacquer the entire wheel, use about 4 coats for 2K out of a gun, or about 8 coats if you're using aerosol. Job done. This is the way they do it in the factory, so you're guarenteed a factory finish
Pete
Pete
Posted 28 August 2007 - 11:44 PM
thankyou!
so i need some etching primer..... and some standard spraypaint? or some enamel?
Ed
Ed
Posted 29 August 2007 - 09:24 PM
thankyou!
Ed
Either should be fine. Just get some black aerosol. Matt black would be best, he lacquer would stick to it better.
Pete
Posted 29 August 2007 - 09:27 PM
thanks bean, thats great!
i was gonna get cosmics but my wallet wouldnt allow me to... lol
Posted 29 August 2007 - 10:55 PM
are these on ebay £50?
the ones with the reserve not met?
u might aswell go for cosmics if thats what you were looking for. u could get a set of 5 for cheaper than that.
