Hi MarkAde, how have you done the fuel gauge sender unit and what make sender hav you used??
Also could you measure the diameter of the filler neck (outside measurment) as i plan to put a remote AERO TYPE filler in the scuttle panel with a length of hose connected to the original filler neck where the screw on cap fits, to save lifting the bonnet to refuel?
Cheers mark :wales:
The filler neck is 44.3mm so I guess you could call it a 45mm OD.... I did consider extending the neck aswell but typically being a minus there just isn't room!! There's no space in the scuttle panel and I thought about taking it to the wing but again no space because of shocks and the tank being too tall! If I had done it the filler pipe would have been practically level! :nugget:
The fuel sender was from the same places as the guages (Revotech).
