Definate understatement. Apparrently the way a mini subframe is set it has a certain amount of bumpsteer built into it.Lowering it and adding big wheels makes it worse. Hopefully next Monday will cure this.Is it bump steering badly at the moment?
R1 engined RWD Mini Minus
#1156
Posted 24 October 2005 - 05:15 PM
#1157
Posted 24 October 2005 - 05:36 PM
#1158
Posted 24 October 2005 - 05:59 PM
Having said that you dont get anything like as many bumps on the racetrack as on the road!
After getting mine setup at zcars i still found that it wasnt very good on the roads where Chris lives (really bumpy). I think getting the car as low as possible helps a lot. I lowered mine at the back after getting back from the Z cars setup and it felt much better.
#1159
Posted 24 October 2005 - 06:04 PM
Did you get it set-up with your 048r's on it Dale?
#1160
Posted 24 October 2005 - 06:06 PM
#1161
Posted 24 October 2005 - 06:07 PM
The main reason i couldn't lower the car any more is that i still had the inner arches fitted for a bit of extra strength and somewhere to route the wires.
When i got home i decided to cut them out and set it to the same ride height as Chris's hyabusa.
I also noticed on his hyabusa that he runs massive negative camber at the front......
#1162
Posted 24 October 2005 - 06:08 PM
#1163
Posted 24 October 2005 - 06:10 PM
#1164
Posted 24 October 2005 - 06:17 PM
#1165
Posted 24 October 2005 - 06:18 PM
Wahoo!!! At least its not all dome and gloom for my Clubby then!There's not much you can do about that unless you are prepared to spend a fortune on lightweight components (titanium arms, mega expensive wheels, calipers etc)...
#1166
Posted 24 October 2005 - 06:26 PM
#1167
Posted 24 October 2005 - 06:30 PM
#1168
Posted 24 October 2005 - 06:37 PM
The unsprung weight also has a similar effect as the springs/dampers and weight of the car has to control the weight of the unsprung bits! ie the lighter the car in relation to the wheels, hubs, discs, calipers, suspension gubbins the more the suspension tends to bounce up and down in relation to the car, making the car unsettled on the road..
#1169
Posted 24 October 2005 - 06:42 PM
#1170
Posted 24 October 2005 - 06:50 PM
