Driveshaft Nut
#16
Posted 13 September 2007 - 04:49 PM
not trying to be funny, just make sure you are undoing it the correct way.
if its broke tools already, its time to get the grinder out
#17
Posted 13 September 2007 - 04:51 PM
#18
Posted 13 September 2007 - 05:40 PM
#19
Posted 13 September 2007 - 08:11 PM
#20
Posted 13 September 2007 - 09:21 PM
Edited by JetBLICK, 13 September 2007 - 09:22 PM.
#21
Posted 13 September 2007 - 09:22 PM
I lowered it down with the wheel on, used a 1/2" drive 1 5/16" socket with a 4ft scaffolding bar on the end of the wrench. H/brake on, wheels chocked. Body weight and afew pushes down and it went with a bang and i landed on me toolbox. but it came off.
#22
Posted 13 September 2007 - 09:52 PM
3/4" drive breaker bars have a higher torque capacity and is the way to go. Personal injury may result otherwise.
but hey, why would you buy the tool for the job when you can just use a pole and abuse the too you have.
#23
Posted 13 September 2007 - 09:54 PM
I had one like this. Had to remove the grp2 arch to get the wrench close enough to car (because like yourself, my extension bar just snapped)
Turning the steering slightly works just as well, no need to take the arches off
#24
Posted 14 September 2007 - 08:08 AM
do not get confused with drum brake cv nuts which are left and right handed threads. The disc brake cv joints are all right handed threads so undo anticlockwise.
yeah i thoiught it mite be a backward thread but the other one was normal so i presumed it would be the same on passengers side?
#25
Posted 14 September 2007 - 08:16 AM
As I said earlier, 3/4" drive is the way to go to be honest. If it's driveable, take it to the garage, give a mechanic £3 for a pint and get him to undo it with his 3/4" drive sockets!
#26
Posted 14 September 2007 - 09:07 AM
Yeah, it's a normal thread on the fronts.
best option! will do that on monday, so impressed by the response on here! some responded with in like 10 mins of me posting originally!!
def worth while staying! seem like a safe bunch!
#27
Posted 14 September 2007 - 10:31 AM
#28
Posted 14 September 2007 - 10:59 AM
So try hitting the end of a resonably sized extension bar (not the scaffolding pole) with a rubber mallet. Using explosive force like that can help undo things when all else fails.
#29
Posted 14 September 2007 - 11:20 AM
#30
Posted 14 September 2007 - 02:22 PM
Ha ha, thought you were going to advise dynamite or something then!Try using explosive force. Sometimes when nuts are stuck, even the leverage from a massive extension bar isn't enough.
Anyone see that Mythbusters with the cement in the cement truck!
