Wheel Spacers
18 replies to this topic
#16 imabitnaughtyxx
imabitnaughtyxx
  • 4,619 posts
Posted 16 September 2007 - 10:09 PM
The original studs that the exensions screw onto are not evenly loaded by them. The way the extensions are locked into the spacer that is trying to prevent them unthreading results in them being unevenly tightened. In theory you can nip them all up to the correct torque then measure how far around each needs to turn to bring them in line, drift the studs back out and turn them in their splines the correct amount. In practice it will never be possible to get them all properly tightened to the correct preload and in line enough to lock into the spacer properly. Also any flex in the fitment will be magnified by the spacer extension and have a greater effect on the extension thread than it would on the wheelnut thread causing it to loosen, made worse by the uneven loading.
In short, the original wheel studs can snap.
YIKES. will have to give this much thought indeed. Many thanks
#17 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 17 September 2007 - 08:45 PM
i agree with Dan, do not use this type of spacer at all :shifty:
Edited by THE ANORAK, 17 September 2007 - 08:45 PM.
#18 Se7enS1ns
Se7enS1ns
  • 472 posts
Posted 17 September 2007 - 09:00 PM
Agreed, and i have personally known them to go wrong, which resulted in the car hiting the deck, wing being bent outwards and A panel inwards.
Please throw them away.
#19 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 17 September 2007 - 09:10 PM
I have personally had the screw on studs on my drums, and extended studs on the front with spacer. I used 12x4.5 rover alloys and never had any problems. the car was driven hard and used on track with no problems what so ever.
On the other hand thought I have now scrapped them as I still don't trust them!
