Big Problems!
Posted 18 September 2007 - 04:13 PM
i turned the heating off to see if it all came back on, but not such luck!
what should i test for, mot soon! this could be a problem, and if it rains! oh dearrr.
any help apreciatied!
Posted 18 September 2007 - 04:15 PM
basicly i got in the car this morning started and drove off the drive, all was fine. i reached down and turned on the heater to clear the window...... it didnt come on.... the Revs gauge, wipers and voltmeter all stoped working too.
Could be that the power to the heater, or any one of the other 'appliances' has been knocked out?
The other week, my radio & heater wouldn't work, turned out they'd piggybacked the radio power feed from the heater switch and the connector had fallen off.
Check all the connections and the back of all the meters/heater etc, if there looks to be a peg/tag with nothing in it and there's a stray connection anywhere its probably that.
Then again I could be talking complete tosh and it could be something as simple as a fuse.
EDIT just re-read, if they all went off when you flicked the heater on, it does sound like something has blown, i.e a fuse.
Edited by yorkshirechris, 18 September 2007 - 04:17 PM.
Posted 18 September 2007 - 04:21 PM
Posted 18 September 2007 - 04:23 PM
Good luck - I hate electrical gremlins!
Posted 18 September 2007 - 04:24 PM
Posted 18 September 2007 - 04:50 PM
Posted 18 September 2007 - 05:00 PM
cheers
Posted 18 September 2007 - 05:09 PM
Take a jumper cable and plonk it across. Thats a nice quick way to check.
Posted 18 September 2007 - 05:30 PM
is this the earth wire?
i presume it should be attached as it looks like its snapped off =/
Posted 18 September 2007 - 05:32 PM
Posted 18 September 2007 - 05:35 PM
it it easy to change the earth strap and where can i get one?
and is it ok to drive it untill the new one comes?
cheers
Edited by insamoufonyx, 18 September 2007 - 05:39 PM.
Posted 18 September 2007 - 05:44 PM
Halfords or any motorfactors sell them or take one of any car at the scrappy
Edited by ratty, 18 September 2007 - 05:45 PM.
Posted 18 September 2007 - 05:46 PM
Check all your cables and anything else that is conductive and connecting the engine to the body because in these circumstances they will usually be badly heat damaged or welded up altogether and could snap or seize at any time, including the throttle.
Posted 18 September 2007 - 06:18 PM
it will be safe to dive it 30 odd miles without it thou? not all in one 15miles each way ( to get to work 2moz) and i can get a earth strap while im at work?
cheers
Posted 18 September 2007 - 06:20 PM
If it starts well there must be another earth. You can't put 350 amps through a few cable casings and get away with it.
