Engine Model And If It Will Fit
Posted 20 September 2007 - 09:15 AM
1275 over bored with 544 cam, double row timing chain, high volume oil pump, larger valves, intake ports enlarged. Motor #12g1279, Head #12g940, trans# 22g1832.
I was wondering what the engine is from and if it will fit in my 1975 Austin Mk3 Mini 1000cc?
And What will i have to modify if i want to put it in?
Could someone who knows about engine numbers give me some information and tell me if it will fit please
Posted 20 September 2007 - 09:20 AM
I'm not sure about the engine numbers. There are a few things that do need to be changed when swapping from a 998 to a 1275, but there are loads of threads about them.
One thing you may need to be aware of is whether you have a rod or remote change gearbox in your shell. I'm not sure when they changed from the earlier remote type to rod type but have a feeling it's around 1974? Someone else will confirm that for me I hope.
Posted 20 September 2007 - 09:30 AM
And can you put a rod gearbox in a remote car?
Posted 20 September 2007 - 09:34 AM
Posted 20 September 2007 - 09:38 AM
Posted 20 September 2007 - 09:39 AM
Posted 20 September 2007 - 09:40 AM
coool now all i need to find out is whether that gearbox is a rod or remote type if someone knows? and what are 544 cams? And what are these little mods?
Posted 20 September 2007 - 09:48 AM
Posted 20 September 2007 - 10:02 AM
That's a rod change gearbox. Remote change boxes have a long alloy casing that houses the gear lever. You can fit a rod change box into a remote shell, I've just done it, but it involves a couple of little mods, that's all.
that? oh thats just a scratch haha
*cough*
Posted 20 September 2007 - 10:04 AM
Posted 20 September 2007 - 10:25 AM
Application Fast Road - Rally
Power Band - 2500 - 7500
Cam Lift(mm) 7.99
Valve Lift(mm) 9.82
Duration 274 Deg
Timing 27/67 67/27
Full Lift 110 Deg
VC (mm) 0.40
LTDC 1.85mm
Not a massively agressive cam, but much better than std, also rather old.. which would tie up with the A series theme of the engine (not A+)
Posted 20 September 2007 - 10:29 AM
Posted 20 September 2007 - 10:32 AM
Posted 20 September 2007 - 10:34 AM
Posted 20 September 2007 - 10:39 AM
