Conversion To 5 Speed Gear Box
#31
Posted 21 September 2007 - 07:27 AM
I disagree with Ethel, why not have more gears? If the engine is strong enough to have a longer first then the whole gear range gets longer with a 5 speed, or you just have the 5th as an overdrive on the lovely motorway.
#32
Posted 21 September 2007 - 07:41 AM
The problem is, running that high final drive, puts HUGE stress on the gearbox and diff...
How many MPi's running a 2.7 FD have we heard about which have blown the diffpin out the back of the box or stripped gears...
The mini is not a modern car... stop trying to drive it like one !
#33
Posted 21 September 2007 - 07:56 AM
The 5 speed boxes with overdriven 5th, you won't gain any acceleration, and your top speed probably won't be much different (the mini is still a brick against 100mph airflow), it'll just drop the revs by a few hundred rpm at motorway cruising speeds. You'd have to be doing A LOT of motorway miles to regain the money you spent on the box in petrol you save!
As said above, just make sure you have the correct final drive for the type of driving you'll be doing. The four speed box really is suitable enough for nearly all situations.
#34
Posted 21 September 2007 - 09:07 AM
With the 5 speed boxes with the direct (1:1) 5th gear, yes these would theorectically give you quicker acceleration, but the small gain in acceleration from gearing is probably going to be spent shifting through the extra gear!
with it costing me around £7 a day to do 30 miles motorway i would imagine it would be worth it, when im going down the motorway at 70 im reving at 3,500 and lets me honest who achualy does 70 on the motorway?
#35
Posted 21 September 2007 - 09:11 AM
but living in Cornwall mean's most shows are over 3 hours away so its nice to sit in 5th on the motorway and drop the revs down that little bit lower the noise level and have a bit more MPG
the 5 speed box gives me a low and high gearing in 1 box
#36
Posted 21 September 2007 - 09:16 AM
#37
Posted 21 September 2007 - 09:20 AM
Your calculations for 3,5k@70 would be about right... 3.1:1 FD
You have one of the best distance ratios already in your car, anything less (2.9 would make sod all difference) would need to be a 2.7, and to be honest, don't even go there...
By you're own admition, you don't stick to 70, which means your poor mini is chucking in fuel by the bucket load... I can drive my 1330 which is not the most economical of engines, along at 60 mph, and return over 30 to the gallon.
On a 30 mile trip, 60 mph on the motorway, vs 70 is only going to take 4 minutes longer...
I don't understand the concept of spending money to save money... say you save a pound for every 30 motorway miles you run, that means you'll have to drive 45000 motorway miles before you've recouped the cost of the gearbox, let alone fitting it...
IMO, money would be better spent finding out why you use £7 fuel on a 30 miles motorway trip.. whether it be a fueling/mechaincal issue with the engine, or just a heavy right foot...
#38
Posted 21 September 2007 - 09:30 AM
cheers
#39
Even if you get 55mpg after you fit a 5 speed box, your talking a hell of a lot of miles before you recoup the £2000+ you'd have to spend on buying one. MUCH easier and quicker to get a different FD fitted and uprated diff pin.
#40
Posted 21 September 2007 - 09:45 AM
You're still right that a 5 speed box isn't where you want to be looking to sort out mileage like that..
Mind you empty pockets would make you think twice about stamping on the go pedal.
#41
Posted 21 September 2007 - 09:46 AM
30 divided by 1.62 = 18.5mpg See me after the lesson young master Jammy
i was quite confused when i looked at jammy's figure lol! this sound more like it, what should i start by doing to sort this out, because at the minute its rediculas!
#42
Posted 21 September 2007 - 09:47 AM
My point still stands though!
#43
Posted 21 September 2007 - 09:53 AM
#44
Posted 21 September 2007 - 10:01 AM
Edited by JetBLICK, 21 September 2007 - 10:02 AM.
#45
Posted 21 September 2007 - 04:40 PM
I'd be tempeted to get the car on a co2 meter, and serviced... and also get yourself a vacuum gauge... that'll tell you immediately if you're running around on more than part throttle..
already have a vacume gauge, what should i look for on that? throttle about half way the needle is on drive, foot to the floor it sits back on the needle again?
