you can fit a battery cut off switch, but if you fit an inline fuse between the 2 terminals, and fit a fuse thats powerful enough to just run the alarm so if someone tries to start the car, they wont and the fuse will blow. just an idea
so would i then just have to replace the fuse and everyhting will work as normal ? will the alarm and imobbiliser need ot eb re set or will they be fine
so put in somehting liek mini misison said http://www.minispare....aspx?pid=36489
yeah you would have to reset the alarm after changing the fuse. and the thing that you found on minispares is what i meant, or you can use the other type with the big red removable key.
although even with a switch, someone who is going to hotwire your car will find it and just connect the wires together.
