Clutch
Posted 09 October 2007 - 05:41 PM
put spring washers onto the clutch when building it up otherwise they will fail!
Posted 09 October 2007 - 05:43 PM
Changed the clutch on my project black one, on tuesday last week. Found all the bolts loose and big chunks of metal missing as they have been ripping apart as the engine was turning.
See pics
Edited by Jordie, 09 October 2007 - 05:44 PM.
Posted 09 October 2007 - 08:03 PM
Posted 09 October 2007 - 08:07 PM
Posted 09 October 2007 - 08:13 PM
not his fault dan, he built it using the parts supplied. the clutch failed as it isnt a competition clutch and cant handle the power i am putting through it. he did say i should uprate it to a better one. i didnt think it would fail this quickly. it is due to how quickly it spins up now that made it release. as i said, spring washers should make it hold in place now. everything else thats being held with spring washers is holding securely.tel really think you should change your mechanic ????
Posted 09 October 2007 - 08:25 PM
But you get the same washers and bolts no matter which clutch you use...?the clutch failed as it isnt a competition clutch and cant handle the power i am putting through it.
Posted 09 October 2007 - 08:30 PM
Posted 09 October 2007 - 08:33 PM
might give them a ring 2moz and see because its 90quid down the drain
Edited by Ollie180, 09 October 2007 - 08:36 PM.
Posted 09 October 2007 - 08:45 PM
Posted 09 October 2007 - 09:37 PM
i am using after market washers now. ones that wont let the bolts come adrift. the standard washers are just a bit pony in my opinion. something that spins that fast and thatquickly needs something that will cope, obviously the standard items cant.But you get the same washers and bolts no matter which clutch you use...?the clutch failed as it isnt a competition clutch and cant handle the power i am putting through it.
Posted 09 October 2007 - 10:00 PM
Gauranteed that the bolts were torqued to the wrong setting!!
Posted 10 October 2007 - 06:21 AM
s funny but alll torque settings were adhered to.Ho ho ho, theres another one.
Posted 10 October 2007 - 06:22 AM
my clutch was from mini spares. it was an ap i think. cant remember tho to be honesthmm this happend to me not long ago
snapped 3 bolts
where did ytou get the clutch from? did you get your money back imstill thinking abotu sending it back but i dont think i would get money back
Posted 10 October 2007 - 06:56 AM
