Have a look at the way in which the door opens. The part of the hinge that goes on the door would move differently to the part that goes on the A-panel.
I totally agree... But what I'm talking about is
removing the hinge pin, so that when the door opens the door-mounted half of the unit can swing away from the A-pillar mounted piece. Weight is still borne on the internal hinge, which is unmodified. The A-panel half never moves, and never has to bear any weight - it's simply cosmetic.
The external hinge looks to only be held together with a single pin, and logically the halves should return to their starting position when the door is closed (assuming of course that your internal hinges aren't loose or rusting, allowing the door to move vertically).
Edited by ImagoX, 17 October 2007 - 04:33 PM.
