CORRECTION:I inquired about the 21251 and 21253 pistons on another board I frequent. I received both catalog information and user testimonials.
My statement about different production materials was incorrect, there is no mention that the two piston types are anything other than cast (and they are probably cast with the same materials). They are both dished with an 8.4cc dish volume. What is different is the design of the two piston types.
The 21251 piston is designed to produce a compression ratio of up to about 8.8:1. They use a 4mm oil control ring and have a wrist pin height of 1.469".
The 21253 piston is designed to produce a compression ratio of up to about 10:1. They have a wrist pin height of 1.528". They use 3mm oil control rings and different drain-back slots design to reduce breakage.
I stand by my earlier comment that the 21253 is a more performance oriented piston than the 21251 but I apologize for implying that the two used different materials and methods of manufacture.
EDIT:
I got the following reply to my query on another message board. It made me chuckle. Have a good weekend guys.
" lots of knowledgeable Mini race engine builders believe that the 21253 is suitable for vintage racing at modest compression ratios and RPMs. Quite a number of vintage Mini racers have used the 21253 at one time or another. The 21253 should be more than enough for most street motors. But then, some people can break a hammer. "
Edited by dklawson, 02 November 2007 - 07:52 PM.
