I've just had my current head worked on by a good VX guy at his machine shop. He is an advocate of not going massive on the porting side of the VX......a view many others hold.
The biggest and again not overly expensive change I made which made a huge difference was to fit a lighter steel flywheel. This made the car rev like a bike engine (or it felt like anyway) and I've got the same on current car......what a difference to the standard overweight lump.
As I said before the biggest restriction on my application is the induction dog leg. You get yours delivering the goods via a straight inlet and coupled with the economic route of the 420H cams you'll be more than happy......with the lightened flywheel you'll be ecstatic!!!!! In a mini this motor will pull it along like a Jet Fighter on re heat.
Problem is then Mike although your car will be brutal don't go driving someone elses who's gone the 450 solid route with forged pistons, big valve head etc. or you'll fall into the same trap as I did.......................you'll then have the "ministry of war" on your back the way I also did
Looking forward to seeing your decisions on the spec. I'm sure you'll get it right!
Cheers,
Kenny
