you cant moan about having to change a cam on an engine your building up yourself! lmao. And with a 1430 you need cooper s rods n e way, so thats all normal. So rubbish, 7 port is just as much hassle as 8 on a 1430 self build. The only thing you would have to actually spend more money on if putting a 8 port head on a 1430 rather than a 7 is longer push rods which cost pennies!
I wasn't saying that physically changing a cam was a problem, that's not the difficult bit is it!
I was thinking more along the lines of having more cam options, having more exhaust options, cams are cheaper, manifolds are cheaper and more readily available, they're all tried and tested, you can get stuff second hand, you can use the same rocker gear, you can...........
Actually, you seem to know it all, dunno why I bothered to offer an opinion to someone that dared to be different to yours!!!
IMO the main issue (as said above) is the distribution of the inlet charge on a siamese port system. This is exaggerated on anything but split webers or twin SUs, the way the fuel flows into the outer two cylinders is NEVER the same as the way it flows into the two inner cylinders. The centre exhaust port still gets shared across 2 cylinders on a 7 port head, so what! As for building an 8 port over a 7 port, of course you're going to have to do extra work for the 8 port build, the valves don't even open in the same order IIRC. I think they are arranged inlet, exhaust, inlet, exhaust, inlet, exhaust, inlet, exhaust, not exhaust, inlet, inlet, exhaust, exhaust, inlet, inlet, exhaust. Building a 1430 is nothing special, there are hundreds of them around, adding an 8 port head into the equation would make it a far more complex/different build. Adding a ready made 7 port head is a bolt on option!
