I'm using a cork gasket. I tryed using grease at first but every time i tryed tightening the studs down the gasket just slipped inwards into the rockers. After about 5 attempts with this gasket and sealing method i gave up and bought a new gasket because the other one got recked because it was covered in grease. So now i'm using hylomar blue.
I put a layer of hylomar around the rocker cover and positioned the gasket on it. I flipped the cover over on a flat surface and left for 2 hours in a warm room. I came back to it and the hylmar had set slightly - Holding the gasket quite securly in place. So i cleaned the cylinder head mating surface with meths and scraped off any old sealent/C**p that was on it until it was clean metal. I then added another thin layer of hylomar to the mating surface of the cork gasket. i then let this settle for 10-15 minutes.
I then gently lowered the cover into place making sure i didn't disturb the gasket position. Once in position i checked the gasket - it was perfect and equal all the way round. So i put the studs on and tightened them down slowly and equaly - 5 turns each at a time, checking the gasket as i went along and made sure i didn't tighten them too tight. Once they were on i checked the gasket - it looked perfectly positioned all the way round. So i left that to settle for 5 minutes, made a final check of the gasket before starting the engine. It all went smoothly at first everything was running nice and smooth and quiet. So i let it get up to running temperature then gave it some revs (up to about 2500rpm) and checked everything - It was all fine! I thought at last its done!
So i leave the engine running for a while since its not been ran properly for a couple of weeks - Have one last look at the gasket and the bloody thing has slipped inwards again into the rockers! About 2 inches of the gasket have come out of place and are flapping about in the bloody rockers!
Now what the hell did i do wrong!!! Arggggggggghhhhhhh!!
Am i supposed to leave the hylomar to set before i run the engine?
I don't have a clue what else to try! What more can i do?
