Reggie!
1535 replies to this topic
#121 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 14 December 2007 - 02:30 PM
hmmm, theres loads of movement in between the two pieces.
its leaking a little, not very much... but at the front of the y piece, the two that join seem to both move just on tick-over :o
is that normal?
The clasps won't go any tighter :dozing:
I made it to the interview, yep! and got an unconditional offer of a place!! :dozing: :sneaky:
#122 GraemeC
GraemeC
  • 7,473 posts
Posted 14 December 2007 - 02:40 PM
I'm confuzzled - why do you now have two looms to do the same job?
#123 wolfys_mini
wolfys_mini
  • 2,493 posts
  • Local Club: many!
Posted 14 December 2007 - 02:42 PM
the link pipe to y piece? or the top of the y piece into the exhaust manifold?
#124 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 14 December 2007 - 02:46 PM
the y piece to manifold...
where the y piece links to the 2 pipes, lol :o don't know techy jargon! :dozing: :sneaky:
Graeme... apparently i don't need one of them, now :crazy:
I thought I had to use that one to connect it to the centre clocks... as a mod to the existing wiring.... but apparently i can just modify what's on there now :dozing:
#125 wolfys_mini
wolfys_mini
  • 2,493 posts
  • Local Club: many!
Posted 14 December 2007 - 02:48 PM
i wonder why its done that.
isnt there a bracket by there somwhere? i wonder if the bracket has undone a bit and is letting it move.
#126 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 14 December 2007 - 02:57 PM
all the brackets are done up tight... but the vibrations are making them move.... which means its not secure in the manifold/y piece join...
which means this could happen again! :sneaky:
i've tried tightening the 2 clasps that are on the end of the y piece... but they won't go any tighter
and now my hands hurt :o
#127 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 14 December 2007 - 03:08 PM
Here he is - the PITA :sneaky:
Attached File  reggie.JPG   75.64K   45 downloads
Attached File  reggie2.JPG   108.29K   47 downloads
Don't comment on how utterly filthy he is.... i already know :o
#128 *DJH*
*DJH*
  • 4,972 posts
Posted 14 December 2007 - 03:29 PM
If you think that's dirty, you should see mine :sneaky:
#129 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 14 December 2007 - 03:36 PM
yeah - but for me!
I'm such a clean freak when it comes to the car! Normally when the slightest bit of dirt gets on him, I wash it off straight away...
But now - he's just utterly filthy, lol :o
Ah well - I've just whacked some of that Holts sealant stuff on the exhaust now :sneaky:
I'll take it off again in a few days, but I need him for tomorrow, so this will do for today and tomorrow.
#130 *DJH*
*DJH*
  • 4,972 posts
Posted 14 December 2007 - 03:47 PM
yeah - but for me!
But now - he's just utterly filthy, lol :crazy:
Oh :crazy: if you ever have a cleaning urge, just let me know and you can do mine for me :sneaky: :dozing:
Ah well - I've just whacked some of that Holts sealant stuff on the exhaust now :dozing:
Yeah, that'll be fine for the next two days :o
#131 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 15 December 2007 - 07:48 PM
Yeah, that'll be fine for the next two days :ermm:
or not.. >_<
Went to Banbury this afternoon.. got me all the way there with no problems. Then went to get some cash out before going for lunch...
Come out of the garage and VRRROOOOMMMMM scrape dugga dugga scrape..... >_<
>_<
>_<
Thank you Mike, for crawling around on the floor this afternoon, fixing him! >_< :w00t: :xxx:
And fanks for my arch trim, too!! :xxx:
And my heater... :dontgetit:
>_<
Thank you for maintaining my mini, because I'm utterly useless!!! >_<
#132 *DJH*
*DJH*
  • 4,972 posts
Posted 15 December 2007 - 07:50 PM
Oh >_< didn't you put the exhaust clamp back on? :)
#133 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 15 December 2007 - 07:53 PM
yep... they were on as tight as i could possibly do them...
but apparently the whole system is twsited, so it'll never fit perfectly >_<
#134 *DJH*
*DJH*
  • 4,972 posts
Posted 15 December 2007 - 07:55 PM
but apparently the whole system is twsited, so it'll never fit perfectly :w00t:
Oh right :)
i suppose you'll get a new exhaust system next year >_<
#135 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 21 December 2007 - 07:44 PM
Well, my paranoia has got the better of me ... :errr:
I'm going to attempt to get rid of Reggie's only rust patch! :(
On the O/S front panel, just below the bumper... I think the paint cracked and so water has got in behind the paint and has started eating away at my wubly Reggie! ^_^
(Admittedly, it's a VERY small line of surface rust, and nothing major at all! :P ..... under an inch long :P )
But I'm worried about the crappy weather getting into it and making it worse, so I'm going to sort it out ASAP.
I took Reggie up to a body shop and they said that it would be £75 to do...
But I'm going to attempt it myself! :ph34r:
So, with instructions from Mr Pikey:
its not hard. :P
wire wheel/brush to get rid of all the crud.
treat the rust
run some coarse sandpaper over it
run some filler over the rust if it's pitted up.
sand again.
mask bits you might get paint on. DON'T mask on the panel itself. it'll leave a hard line. Just "feather" it.
primer (and a few inches either side)
rub smooth with some fine sandpaper
paint. about 5 light coats should do it. And again, feather the panel.
leave it a couple of days to fully harden (you can use the car in that time)
wash
using LOTS of soapy water, take some light wet and dry and just smooth it out
polish and wax
easy! ;)
I will be going to get some primer tomowwow, along with a range of sandpapers! And I should have enough paint left in the can to spray it up... but I'll double check that and if not, I'll get some more! :ermm:
Wish me luck! :dontgetit:
