Lifting A Complete Engine On A Complete Subframe
35 replies to this topic
#1 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 02 December 2007 - 10:41 PM
Well i have been a busy boy and have aquired a 1275 engine on the subframe with everything for my auto-manual conversion. I collected it the other day and the person i bought it off had a engine crane to get it in so it was all easy.
But
now i have to get it out of the back of the car >_< >_< i dont have a engine crane and i dont really intend on buying one
or hiring one. (i dont have the space for one and hriing one will be a right pain in the uhum for me)
It looks really really really heavy and because the subby is all complete and everything its hard to place your hands any where to lift it.
I had a plan of lifting it down onto a creeper and wheeling it away.
Does anyone have any tips on how to lift it and where me and my brother should lift it from ?
Edited by ultimate, 02 December 2007 - 10:46 PM.
#2 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 02 December 2007 - 10:51 PM
you want to lift the engine and subframe together? good luck dude. if you have to get about 6 guys and you might make it.
#3 scottyegg
scottyegg
  • 394 posts
Posted 02 December 2007 - 11:08 PM
to avarage man can lift an engine out easyish with rope and two lengths of wood id recomend 3 4 guys
#4 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Nah it can be done needs about 4 strong blokes though!!
#5 Ethel
  • 26,073 posts
Posted 02 December 2007 - 11:38 PM
Don't lift it if you can hang it off something: jack the car up; tie the engine up; lower the car; drive it out of the way.
#6 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 02 December 2007 - 11:43 PM
can you borrow the engine crane from the guy you bought the engine from? >_<
#7 mini_kev
mini_kev
  • 716 posts
Posted 03 December 2007 - 02:48 AM
Take it off the subframe? its only four bolts so wouldnt be too much hassle
#8 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 03 December 2007 - 07:39 AM
I am really thinking of taking the engine off the subframe but the driveshafts are still connected and reading the haynes it says i need a ball joint splitter to disconnect things at the hub end ??? Can i not just take off the driveshafts off from the engine so i can lift it off ?
Or i was thinking of jacking the sides of the subframe up, putting some wheels on it and try wheeling it down two planks of wood ?
But then it has to go up a 2 steps and sideways into the garage :ph34r: (that is if i get my way and get to keep it in the garage)
#9 Jammy
Jammy
  • 25,397 posts
Posted 03 December 2007 - 10:08 AM
Nope, you can't take the driveshafts out without splitting the balljoints. Its, say, an in built safety feature which means a driveshaft can't just pop out whilst your driving along!!
The complete package has got to weigh in at nearly a quarter of a ton! It may require 3-4 blokes to lift it out, but can you get each guy in a position where they can lift it effectively? Ethel's idea sounds like a good one, but make sure whatever you tie it up to can take the weight.
For all its worth I'd just rent an engine crane for a day or two. My local tool hire place is cheap enough to deliver and collect too!
The other way would be to slowly dismantle it in the car.
#10 Elfie
Elfie
  • 608 posts
  • Local Club: Teeside Yesteryear Motor Club
Posted 03 December 2007 - 10:13 AM
Me, a mate and another guy lifted mine into the back of a fairly small car. It was fully laden with oil and had all the bits attached, hubs etc.
It was immensely heavy though. Youll be able to do it with 3 people minimum
#11 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 03 December 2007 - 12:10 PM
you can split the top ball joints with a hammer, which allows the hubs to fall outwards and the drivershafts to be removed. given space?
Else it's probably an engine crane or hoist,
#12 turbopixie
turbopixie
  • 47 posts
Posted 03 December 2007 - 12:53 PM
It can be done just watch your back, me and a friend lifted a subframe and engine from the back of a van onto a trolly, didn't have drive shafts or hubs.was not easy though :ph34r:
#13 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 03 December 2007 - 03:39 PM
Really depends what sort of car it's in at the moment, if it's a hatch back then good luck to ya'... an estate you can usally just push them out onto something soft if worst comes to worst...
#14 alexcrosse
alexcrosse
  • 3,786 posts
Posted 03 December 2007 - 03:49 PM
dissassemble it. Ull want to look throughout the engine anyway. Take the head off (15kg gone) and just start ripping. Then u can clean n rebuild the engine. Just an idea, tis what ii would do.
#15 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 03 December 2007 - 04:23 PM
I havent got any tools with me as my toolbox is lying in my brothers garage
I dont know what to do, i might try jacking it up and putting wheels on it so it is at least mobile. Its all lying inside a mpv.
I need to get it out now :ph34r:
Edited by GreaseMonkey, 03 May 2009 - 08:33 PM.
