Compression Test - Can Anyone Come Round To Help Me?...
Posted 18 December 2007 - 07:36 PM
im (still) having big problems with my engine and ive checked everything apart from the coil and doing a compression test as far as i can think of. the list of replaced parts is now: starter motor, dizzy, dizzy cap, points, condensor, sparks, HT leads and carb needle and im sure a few other bits and bobs. ive checked over the carb and seems ok, fuel still going in so i guess pumps ok, all plugs are sparking and im running out of ideas. hence a compression test is overdue!
so, can anyone local with a compression tester come give me a hand maybe? wednesday 2pm onwards or thursday, friday, saturday all day would be great. im trying to get her running for christmas eve you see, to get to the girlfriends and back on christmas day.
thanks
Posted 18 December 2007 - 07:43 PM
Posted 18 December 2007 - 07:45 PM
Posted 18 December 2007 - 07:49 PM
yeah but im lazy also my dad one but hes lost it in the garage somewhere...and i wouldnt know where to start with using one
Won't it have instructions
Posted 18 December 2007 - 08:01 PM
What is the problem with the engine? Not starting?
Posted 18 December 2007 - 08:03 PM
Posted 18 December 2007 - 08:28 PM
Take all plugs out
Screw comp. tester into plug hole
Reset gauge (button on side)
Turn engine over with foot flat to the floor
Take your reading
Reset gauge and remove
Repeat another 3 times
All your really looking for is a cosistency between all the cylinders.
Posted 18 December 2007 - 08:51 PM
Worth checking valve clearances before you do a compression test, they make a huge difference.
it starts most of the time now but cylinders 2 and 3 are barely making any difference to it running, i cant even be totally sure theyre firing. so its basically running on just 1 and 4 and has a huge lack of power.
how do i check the valve clearences? id look at the haynes bible but i havnt got it with me at the moment.
Posted 18 December 2007 - 08:55 PM
You cant be arsed to go to a motor factors and buy one but expect someone to be arsed to travel to yours and help you out?? |
well its not totally true. i would go get one if i knew what i was looking for in the readings i get and what to do from there on, but i dont. so basically im asking for someone with a lot more experience with engines and minis to help me out, im not just looking for someone to bring me a compression test.
Posted 18 December 2007 - 09:13 PM
Posted 18 December 2007 - 09:29 PM
is there any oli in the coolant?.
shouldnt be. that was part of the servicing we gave it about a month ago. does remind me i need to change the oil tho
Posted 18 December 2007 - 09:33 PM
hopefully not, that would just be discusting.
Posted 18 December 2007 - 09:40 PM
the compression should be anything over 80psi with all 4 cyls running +-20psi(max) to each other.
basically screw into a plug hole, turn engine over until scale steadied and read....repeat on all 4.
std rocker gap is 15thou, see haynes how to check or search on here(its there somewhere)
Posted 18 December 2007 - 10:05 PM
if there was oil in water about a month ago then it will still mean the headgaskets gone, and will now only have mixed back in, dont bother with the oil until thats checked,
ah right. cheers that helps alot but if i get low readings for any of the cylinders, which im expecting on 2 and 3, where do i go next?
Posted 18 December 2007 - 10:14 PM
