Compression Test - Can Anyone Come Round To Help Me?...
#16
Posted 18 December 2007 - 10:15 PM
but if there is no oil in the water or white stuff under the oil fill cap it could be a valve problem.
best thing to do is get a compression test done then get back to us and we can help some more.
with out the compression test we cant really comment.
as you have sparks on all 4 plugs and petrol.
jay
#17
Posted 18 December 2007 - 10:17 PM
is there any oli in the coolant?.
hopefully not, that would just be discusting.
there is a reason i ask this.lol
#18
Posted 18 December 2007 - 10:22 PM
if you had oil in the coolant and low readings i would say head gasket.
jay
havnt noticed any white stuff anywhere but ill give it an extra close look tho.
ok ill do a compression test and hopefully post the results tomorrow.
cheers
#19
I know there is a reason you ask this. I spent 5 years working on cars and the past 6 fixing jet engines. If you read the bit i've underlined and put in bold it says OLI not oil. It was a joke as the person that started the post is oli8925. Was supposed to be a joke. A little light hearted humor. a little fun from your typo.
Edited by BoboGib, 18 December 2007 - 10:23 PM.
#20
Posted 18 December 2007 - 10:26 PM
i didnt even notice that said oli.
#21
Posted 18 December 2007 - 10:29 PM
#22
Posted 19 December 2007 - 12:57 AM
Also if 2 and 3 are not making a difference to the running then it could be a Head Gasket problem.
#23
Posted 19 December 2007 - 10:28 AM
As you said Cyls 2&3 were not making much difference, have you checked they are wired correctly? It's a very simple mistake to make as I have done it recently after installing a new engine! It baffled 3 of us for hours, and one of the other blokes was an experienced (24yrs) mechanic!
I only say this as you state that you changed the HT leads recently, and it does't take much to get them wrong. Go through the haynes and make sure everything is done to the letter.
Other than that, the compression tester is pretty simple, the Gunson one I bought from Halfrauds a couple of years ago came with all the instruction you could need printed on the back of the box. One thing I would add to the comments here though (if it's not written on the box) is if you only unplug/do one cylinder at a time then make sure you remove the coil lead to the dizzy, as you don't want the engine starting up - only turning over for about 6-8 seconds.
#24
Posted 19 December 2007 - 01:57 PM
Strebblo makes a good point to check the leads..it takes 5 mins to check and could save you the cost of a compression tester.
#25
Posted 19 December 2007 - 09:30 PM
remove the oil filler cap to see if theres white stuff there, maybe there on any car if only just done short run due to condensation, compression test best way to tell.
check points gap
check the plugs gap(25thou) if ok try diff plugs if you can get hold, note the colour of the plugs, if 2+3 are petrol wet then its not firing
remove the plugs one at a time and hold just away from a bare metal part of the engine turn engine over see if it sparks
make sure the ht leads are ok as above
#26
Posted 19 December 2007 - 09:53 PM
#27
Posted 19 December 2007 - 10:00 PM
as for wiring ill give it all another check but i and my dad have gone through literally everything outside of the engine block hundreds of times so im almost certain its correct. best be sure tho.
yeah was gonna ask about the dizzy-coil lead lol. i didnt see how the test would work if the engine ran so thanks for that.
points and plugs gap has been checked hundreds of times too but ill give everything another check just for good measure and theyre all new with spares available. all of them are sparking. 2 and 3 seem to be incosistent also in that a few times on saturday the plugs were wet but not always. did always get very sooty tho. 1 and 4 seemed to be fine. ive had this running problem for 3 months but none of the plugs were ever wet before
another thing odd to happen was that for 5 minutes it ran perfectly on 4 cylinders, i drove it just up the drive, let my dad in to go for a test drive, went to move off and it had lost all power again and back to 2 cylinders. its done this one or 2 other times during its problem months and just seems to make no sense at all!
id like to just send it to a mini specialist garage to sort out but im scared about the labour costs lol. or just a new second hand 998cc A+ engine but havnt been too many going around in my area so im stuck with my old rust bucket
#28
Posted 20 December 2007 - 08:58 AM
#29
Posted 20 December 2007 - 11:46 AM
try cleaning the sooth off the sparkplugs, it could be that the spark is not jumping well due to the sooth.
cleaned them evertime i checked them but they just go back to being sooty everytime
#30
Posted 20 December 2007 - 12:01 PM
what were the results?
