Using Too Much Petrol?
59 replies to this topic
#16 Mini Man Dan
Mini Man Dan
  • 1,299 posts
Posted 01 January 2008 - 08:03 PM
First question, how much are you putting in to a 'full' tank? You'd be amazed how many people seem to think you can only fit 20 litres into a Mini, or even less. It should take around 30 to 32 litres to fill it from when it's pretty empty but still perfectly driveable. It's a 34 litre tank. Work out your economy by using your fuel receipts and your odometer, not by some vague idea of a full tank.
:proud: you are correct I have made a mistake straight off. Just worked it out I am getting just under 20MPG
#17 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 01 January 2008 - 09:56 PM
Do you drive mostly motorways or mostly around town?
#18 Mini Man Dan
Mini Man Dan
  • 1,299 posts
Posted 01 January 2008 - 10:03 PM
Mostly round town.
#19 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 01 January 2008 - 10:58 PM
You should probably be getting high 30s to low 40s then if you don't drive with a lead foot.
Edited by Dan, 01 January 2008 - 10:59 PM.
#20 Minigirl
Minigirl
    With Steve
  • 1,109 posts
Posted 01 January 2008 - 11:12 PM
I'm not 100% sure what it would be
but dont forget town driving does use more fuel than motorway driving from stopping and starting so much
i had the same problem with my mini but when she had a good service, changed air filter, and changed the mixture it seemed to sort it out
#21 Globule
Globule
  • 1,134 posts
Posted 01 January 2008 - 11:32 PM
Mine's kind of the opposite, i got about 100 miles motorway driving from a full tank (well when the pump clicks repeatedly and just wont let anymore in!) and when i got back i was well into the red! Around town a full tank lasts me more than that if i drive gently!
#22 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 01 January 2008 - 11:38 PM
Yeah, it's only more economical to sit at one speed if that's the most efficient speed for the engine and the aerodynamics and gearing have a big effect on that. The most efficient speed for most Minis (excluding the City E gearing I believe) is around 55 MPH, so on a motorway you don't get the same efficiency as you do with a car that could drop into a higher gear at motorway speeds or one that slips through the air more elegantly than a garden shed unlike the Mini.
#23 Mini Man Dan
Mini Man Dan
  • 1,299 posts
Posted 02 January 2008 - 01:36 PM
Cheers everyone, been a great help!
Will have to find a rolling road locally I think and double check everything again to see if there is anything stupidly obvious.
Dan
#24 insamoufonyx
insamoufonyx
  • 1,633 posts
  • Local Club: NorthSomersetMiniClub.co.uk
Posted 02 January 2008 - 02:07 PM
i only get 13mpg :) :) lol need to sort that at some point
#25 insamoufonyx
insamoufonyx
  • 1,633 posts
Posted 02 January 2008 - 02:11 PM
Surely not all minis are 34 litre tank? ive run out of petrol before by a morrisons. i completely cut out so pushed it into the petrol station filled up from as empty as empty can be the stupid pump didnt click off so it wover flowed all down the side of the car and my foot, and that was only 24litres.....
#26 mkw
mkw
  • 1,003 posts
Posted 02 January 2008 - 02:16 PM
you may have the smaller tank, 5.5 gallon is it?
#27 Mini Man Dan
Mini Man Dan
  • 1,299 posts
Posted 02 January 2008 - 02:25 PM
Yeah I think the smaller tank is 5.5 gallon
#28 Jammy
Jammy
  • 25,397 posts
Posted 02 January 2008 - 02:45 PM
There are two sized tanks, 5.5 gallons and 7.5. Only really early minis had 5.5 gallon, and I believe they are actually getting a touch rare, although you can usually find a couple at shows. I think Mk3 onwards had 7.5 gallon tanks.
If the petrol tank sticks out further than the side of the bootlid, then you have a 7.5 gallon tank.
#29 Ethel
  • 25,971 posts
Posted 02 January 2008 - 02:59 PM
I think the big tank started out on the 1275GT (replacement of twins on S's ). Don't think they became standard till the 80's.
#30 Jammy
Jammy
  • 25,397 posts
Posted 02 January 2008 - 03:14 PM
I'm sure my '76 Clubby came with a 7.5 gallon tank.
