I'm sure my '76 Clubby came with a 7.5 gallon tank.
My old '76 GT had a 7.5 gallon Tank
Posted 02 January 2008 - 04:38 PM
Posted 02 January 2008 - 04:51 PM
Posted 02 January 2008 - 04:53 PM
Posted 02 January 2008 - 05:17 PM
Depends how much your filling up with everytime???
Posted 02 January 2008 - 06:09 PM
Posted 02 January 2008 - 09:07 PM
Posted 02 January 2008 - 10:38 PM
Posted 02 January 2008 - 10:50 PM
I have an unmodified 998 in a 1990 Mini City E and I regularly do a 270 mile journey on a full tank of about 25 litres (according to the pump when filling up with the needle at the bottom of the red mark). That's motorway driving with an average speed of 65mph.
When I do short journeys I get about 200 miles on the same amount.
It used to be worse but I sorted the timing, replaced the spark plugs, cleaned the rotor arm and contacts in the distributor cap, tuned the carb idle, replaced the air filter element, fixed the blowing exhaust at the downpipe/manifold bracket, and correctly set the handbrake cable tension.
I have no idea what capacity my tank is as I never fill it to the neck because it stinks of fuel in the car if I do. So I stick the nozzle in and stop filling at the first click.
Here's the tank before I cleaned it up:
DTXDave
Posted 02 January 2008 - 11:15 PM
Posted 02 January 2008 - 11:22 PM
Really confused now,
the 16 liters always takes the needel up to the top and i fill up when the needel touches into the red marked section,
possible i have a dodgy fule guage? so i'm only ever draining the tank half way?
how do i get to the guage bit in the tank to check it, is there an inspection hatch?
thanks for your advice,
a much apprecitive Jon
Posted 02 January 2008 - 11:37 PM
Posted 02 January 2008 - 11:54 PM
Posted 02 January 2008 - 11:58 PM
I know where the FAQ section is but I can't find the thread you refer toAs I said, there is an FAQ on why you can't fill up a tank with its full capacity. Would anyone like me create a link to where the FAQ section is?!
Posted 03 January 2008 - 12:03 AM
Oh, I don't recommend doing what I did because the crud in the bottom of your tank can be sucked into your carb
Edited by Dan, 03 January 2008 - 12:05 AM.
Posted 03 January 2008 - 12:11 AM
Jon618, I don't know of any car ever made that has a fuel gauge that you would consider to be accurate. They are all different and vague and all they ever show is the level not the volume so exactly what it will show depends on whether you are moving or parked on a hill or something. If you are only getting 16 litres in then you are only using half a tank. Just keep driving next time and push it until the needle gets a bit lower on the gauge, then fill up and see how much you get in. Keep going until you can get somewhere around 30 litres in when filling to just below the join between the neck and the body of the tank (you can see where the level is then through the filler, it should never be filled into the neck). The total capacity is around 34 litres so if you are pushing it to having only about 4 left you are still quite safe. Then just note how low it will actually go on the gauge, the red sector is only a warning on any car. Keep a full jerry can with you when you are doing this testing, just in case the gauge is actually broken but it isn't likely.
AFAIK the 7.5 gallon tank became standard accross the saloon range in 1973, before that it was used on the 1275GT and I think the Mk3 Cooper S only. From then on ALL SALOON MINIS had a 7.5 gallon tank. This is not as confusing as this thread would make it seem.
