Fillet Strip Tool
Posted 03 January 2008 - 11:43 PM
Bad day in the garage, nothing gone right.
Anyway, the fillet locking tool from Mini Spares.
How in holey hell do you use it? Do I just throw it at the screen and swear alot or what? I got no clue how to use it.
Ta for any help.
Posted 03 January 2008 - 11:55 PM
Posted 04 January 2008 - 12:02 AM
you slip the tip of the tool into the groove and turn it so that it pulls the lips apart, feed the fillet into the hole in the end of the tool which keeps the hole open enough to keep slipping the length in.. lubricant helps (fairy liquid and water in a spray bottle will do) then you can drag the tool all the way around the groove. i find it easier with another pair of hands to help.
Posted 04 January 2008 - 12:06 AM
Posted 04 January 2008 - 08:15 AM
in the end i just use a washing line peg, split in half, half to open the rubber other bit to push the strip in. Oh and dont use washing up liquid, way to much salt in it, which you dont want around that scuttle, plus it lets the strip slip back out. just a little spray of plusgas will do it. ( sorry BigGav )
Posted 04 January 2008 - 08:41 AM
are you being rude again ?
Posted 04 January 2008 - 09:28 AM
Posted 04 January 2008 - 10:28 AM
Ive tried with those tools before, and like you Big Adam, ended up throwing the tool as far as i could.
MY BAD!!!!! I really do know better than that!! Car shampoo, even the cheap stuff is what to i use it all the time in a spray bottle for all sorts of stuff.. I was too busy trying to make my post clear and devoid of any innuendo.
Posted 04 January 2008 - 10:29 AM
Are the roller type any good? I've only ever used the blue veined lip splitter
Posted 04 January 2008 - 11:00 AM
Posted 04 January 2008 - 12:46 PM
It takes about 10 seconds to get it done together with some wash up liquid.
Windscreen_Fitting_tol.jpg 121.64K 4 downloads
Posted 07 January 2008 - 10:38 AM
These are brilliant and dead easy to use.
DON'T USE WASHING UP LIQUID!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted 07 January 2008 - 11:16 AM
Washing up liquid is a no no...just take your time and you don't need owt
Posted 07 January 2008 - 12:22 PM
Gotcha,
Posted 07 January 2008 - 12:30 PM
