New Project Mini
145 replies to this topic
#121 jonb_5
jonb_5
  • 575 posts
Posted 10 May 2009 - 05:19 PM
Hi,
Its a 1330 with Kent 296 Cam, and Hif44 carb, which is why i would have liked it to have slightly higher bhp.
I bought the engine complete over the net and after speaking to Neil at Slark racing it appears that the head could do with some work which is why it is not developing full power. Also a new exhaust and inlet manifold will help better flow. These are to be done over next winter as for now it runs great.
Jon
#122 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 10 May 2009 - 06:12 PM
looks ok to me. is it at the wheels or crank?
#123 jonb_5
jonb_5
  • 575 posts
Posted 10 May 2009 - 06:30 PM
Hi,
I am not too sure if it is at the wheels or the crank, how can you tell?
Jon
#124 streety
streety
  • 33 posts
  • Local Club: not yet
Posted 10 May 2009 - 06:55 PM
the mini is looking amazing seriously thinking about having mine the same colour cheers
#125 jonb_5
jonb_5
  • 575 posts
Posted 26 May 2009 - 07:42 PM
Took the mini out for a spin tonight and heres a few pics:
#126 Neco
Neco
  • 105 posts
  • Local Club: Cyprus Mini Club
Posted 26 May 2009 - 08:27 PM
Looks stunning man great job :)
#127 jonb_5
jonb_5
  • 575 posts
Posted 27 May 2009 - 04:09 PM
Few more pics from last night:
Edited by jonb_5, 27 May 2009 - 04:10 PM.
#128 jonb_5
jonb_5
  • 575 posts
Posted 29 May 2009 - 04:53 PM
Hi,
I have been trying to sort out the look of my engine bay so sorted out the wiring, modified and painted the air box, ( i wanted to keep this as it gives better performance than a cone filter) and got rid of the huge washer bottle.
I am going to paint the radiator bracket in blue and also have bought some engine paint that i am going to paint on until the engine comes out, try and smart it up a bit.
Let me know what you think!
Jon
#129 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 30 May 2009 - 01:34 AM
What arches are those, they look quite nice and im looking to change mine.
Ben
#130 jonb_5
jonb_5
  • 575 posts
Posted 30 May 2009 - 09:07 AM
Hi,
The arches are Group 5's, as you can see with the rivets showing, i think you can get similar one where you have to bolt them on from behind but i wanted ones which showed the rivets.
Been playing in the engine bay again, gave the block a quick paint to cover up the red bits showing through and also colour coded the radiator bracket.
Jon
#131 LankyJames
LankyJames
  • 428 posts
  • Local Club: Heavy Handed Cluts Club
Posted 30 May 2009 - 02:50 PM
looks 10x better with the block painted to match!
#132 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 30 May 2009 - 04:44 PM
The whole car looks lovely, really like the colour.
Was the magajolt easy to install and set up?
Where did you buy the megajolt unit itself from please?
Thanks,
James.
#133 jonb_5
jonb_5
  • 575 posts
Posted 30 May 2009 - 06:10 PM
Hi,
The megajolt was very easy to install, the only problem I had was the first trigger wheel I had was slipping on the pulley wheel so I had to buy a different one. Everything else was fine, wiring very simple. I must say that without using this forum and turbominis I would not have been able to do it though, the amount of questions i asked and searches i did helped a lot!!
I got the megajolt from autosportlabs.com in the states. Had it delivered to a work flat and brought back for me. Managed to avoid the import tax;-)
Jon
#134 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 30 May 2009 - 09:31 PM
Oh thanks for that, I was struggling to find a place that sells the unit itself.
Yeah, I found there was lots of info about MJ both on here and turbominis, but without the MJ it doesn't make a lot of sense.
Which trigger wheel do you have now? I think I'm going to buy the MED bottom pulley with the machined in teeth. It would avoid slippage that way :)
Thanks,
James
#135 jonb_5
jonb_5
  • 575 posts
Posted 31 May 2009 - 07:20 AM
That would be my choice if i bought it again - although Tom Fenton on Turbominis sells them on an exchange basis for your pulley, good prce as well just look on the for sale section.
He also makes some decent brackets for the crank sensor if you dont want to make you own.
Jon
