Brake Failure Switch
Posted 24 February 2008 - 06:36 PM
if i could replace the brake failure switch with 1 for the front fogs
Just wondering wether it was essential to have the brake failure switch in or not ?
Posted 24 February 2008 - 06:37 PM
You can buy a 5-switch bezel from most good Mini parts suppliers.
Guest_iansmini_*
Posted 24 February 2008 - 06:41 PM
Posted 24 February 2008 - 07:02 PM
Posted 24 February 2008 - 07:05 PM
Just my opinion, do what you like but personally I'd NEVER replace it with another switch that you could find another place for.
Posted 24 February 2008 - 07:13 PM
Posted 24 February 2008 - 07:15 PM
Posted 24 February 2008 - 07:37 PM
Could i wire the front fogs up to the rear fog switch ?
Or replace any of the other switches with the front fog switch ?
Any ideas or advice would be a help thanks !!
Posted 24 February 2008 - 07:39 PM
None of the others are removable really.
Have you not got a centre console, you could maybe invest in some toggle switches or something for both your fogs? Either way it looks like you'll have to have a think about moving a switch.
Posted 24 February 2008 - 07:53 PM
I'm fitting the Metro Turbo 4 Pot Calipers/Vented Discs to my MPi and was wondering if you could wire the "low pad thickness" sensor into the brake test switch somehow? I assume as it is a "short-out" type switch it could be wired to "close" and light up the existing switch?
Posted 24 February 2008 - 07:54 PM
Posted 24 February 2008 - 08:00 PM
I'll have a go and report back later.
Posted 24 February 2008 - 08:02 PM
You could wire the front fogs to the back fogs I suppose... in fact that MAY burn out the switch so it might be worth asking someone with more knowledge of the current that fogs draw for that one.
Where would you suggest putting a switch ?
Posted 24 February 2008 - 08:04 PM
