Brake Failure Switch
33 replies to this topic
#31 Guest_iansmini_*
Guest_iansmini_*
  • Guests
Posted 27 March 2008 - 09:18 PM
Are these in the position of fogs or spots ?
http://i260.photobuc...11/DSC00116.jpg
They are the standard position for fogs. You can get a works style lamp bar which will keep them all in the same height. You will also find some lamp bars have 2 at that height and two a bit higher, the two a bit higher will have to be spots as there are DVLA regs that require the fogs to be at a designated height from the floor too. This is same applied for the two up two down (that sit on each other there is a project on here that employs this style 70's retroracer i think) With the lamp bars they screw into the two holes that you have the auxillary lights fitted if you buy them separate then you will need to drill in two new holes, but i presume you will know this :o
Edited by iansmini, 27 March 2008 - 09:19 PM.
#32 moggy
moggy
  • 65 posts
  • Local Club: ?
Posted 27 March 2008 - 09:28 PM
Cheers mate i was just making sure the fogs are situated there.
Don't think i'm gonna go for spots as i have just fitted some halogen headlights and they seem bright enough and don't wana hide away the grille i have on.
#33 Guest_iansmini_*
Guest_iansmini_*
  • Guests
Posted 27 March 2008 - 09:30 PM
They can be fitted on the lip at same height side by side too! But as you said yourself it shows your grille better them sat there like that :o
#34 moggy
moggy
  • 65 posts
  • Local Club: ?
Posted 27 March 2008 - 09:41 PM
I have just checked and there are 2 relays placed on the drivers side inner wing.
What will these be for ?
