Water Based Paint
57 replies to this topic
#16 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 01 March 2008 - 10:29 PM
Really I'd have thought panel wipe would evaporate really quickly and it'd go all gummy.. :) I'll try it next week!
#17 jack_marshall
jack_marshall
  • 2,540 posts
Posted 01 March 2008 - 10:33 PM
It does evaporate very quickly but I'm only talking about flatting out minor marks, not disasters!
It does go gummy if you rub any more than very lightly!!
Havnt any of the paint reps told you about it?
#18 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 01 March 2008 - 10:35 PM
Nope our paint reps are useless! I figure it all out myself.
#19 jack_marshall
jack_marshall
  • 2,540 posts
Posted 01 March 2008 - 10:37 PM
Most paint reps are failed painters anyway!
Haha!
#20 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 01 March 2008 - 10:38 PM
Hmmm maybe I could have a new career as a paint rep?!!!
#21 jack_marshall
jack_marshall
  • 2,540 posts
Posted 01 March 2008 - 10:41 PM
Nah, you have to fail at it first I think!
We shall see tomorrow wont we!
Good luck mate, Im interested to see how you get on with it.
Edit- hope theres no paint reps on here.
Edited by jack_marshall, 01 March 2008 - 10:41 PM.
#22 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 01 March 2008 - 10:42 PM
You're interested, I'm terrified!!!
Seamus
#23 In-a-mini
In-a-mini
  • 831 posts
  • Local Club: smag (southend mini action group)
Posted 02 March 2008 - 09:28 AM
Those blowers for water-based paints draw the booth warm air through them onto the panel they dont produce heat themselves. if you warm the air around the car and blow with the paint gun it does do the same just not as well. i have used a paint stripper gun to force dry the paint before does work well but as you said if you are blowing anything towards the paint it can throw debris on to the paint. Oh the joys water based has some really good points but not as user friendly as solvent for diy painting. For my custom/airbrushing i use a water based paint made by createx called autoair it is great for this type of painting where you want to mask over it once heat set 30seconds later you can mask over it.
Hope it turns out ok.
i dont know how much of the car you are painting i have only done max of two panels at once with the water-based (out of booth).
#24 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 02 March 2008 - 09:35 AM
I'm just going to paint the front end and drivers door at the mo.
Might not get to do it today after all, spent most of yesterday replacing rear brakes.
Off out to garage in a bit though.
I've got a half day on Thursday so might do it then
Thanks everyone for your help, very much appreciated
I will post pics up(good or bad) ASAP
Seamus
#25 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 03 March 2008 - 05:27 PM
Hi, right I have started to paint my car and here are the results so far!!
Its in the garage at the mo and I have just put on the first coat
So far it seems to be going quite well, paint is tacking off and going on quite nicely
Attached File  humpfrey_017.jpg   308.9K   76 downloads
Attached File  humpfrey_018.jpg   318.85K   64 downloads
Gonna give the paint another 1o mins to go off and then give it another coat
Wish me luck
Seamus
#26 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 03 March 2008 - 05:29 PM
good luck :lol:
#27 jack_marshall
jack_marshall
  • 2,540 posts
Posted 03 March 2008 - 05:32 PM
Excellent!
Brave man for trying it at home but looks to be going well!
By the way, if you have high solids 2pack laquer, it should be a 2:1 mix of laquer and hardener, but I always put a dash of thinner in to make it sit flatter, more like 2:1:1.
I dont know if it would be a good idea if your conditions are quite cool, but if you find the laquer quite orange peely, then give it a go, but go steady!
Looking forward to seeing the results!
#28 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 03 March 2008 - 05:50 PM
Ok then here it goes 2nd coat!!
To be honest I don't see that much differance yet.
The drying time is longer than 2 pack base cost but it will go off in about 20 mins
Attached File  humpfrey_019.jpg   313.16K   79 downloads
Attached File  humpfrey_020.jpg   305.75K   71 downloads
I am quite happy with the way it looks so far, haven't had the paint fall off onto the floor either
Seamus
#29 jack_marshall
jack_marshall
  • 2,540 posts
Posted 03 March 2008 - 06:24 PM
Definately getting there mate!
Silvery / light colours do take a fair few coats to cover.
Even when it all looks covered, Id give it another one just to make sure as sometimes you get it into daylight and can see through into the primer!
How much basecoat have you used for 2 coats so far then?
Have you thinned it?
#30 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 03 March 2008 - 06:40 PM
Hi, it seems to be covering well, I have used it straight from the tin with no thining and its going on well.
So far I have used @ 1/2 ltr to do 3 coats
Attached File  humpfrey_021.jpg   310.18K   71 downloads
Attached File  humpfrey_022.jpg   309.35K   73 downloads
I think I will give it 1 more coat and then start and heat the garage up in preperation for the 2 pack clear coat.
So far so good
Seamus
