Water Based Paint
57 replies to this topic
#31 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 03 March 2008 - 07:34 PM
Looking good! I always add 10% thinners to the 2:1 lacquer/thinners. What make of lacquer have you got?
#32 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,144 posts
  • Name: Sean
Posted 03 March 2008 - 07:41 PM
Hi, its lechler Macrofan HS flash clearcoat
According to the instructions
its 1000ml+500ml+100ml
I'm quite happy with the way its going.
Can I leave the basecoat to dry overnight or is it best to do it all in one hit?
Is it possible to put the clear on whilst the base is still "sticky wet"
Seamus
#33 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 03 March 2008 - 07:48 PM
Ah that's pretty good lacquer, I'd use it 2:1 with 10% thinners. You can leave the basecoat overnight if you like, in fact it would probably be a good idea if you have no heat, just to make sure it's gone off properly. Just make sure nothing is going to crawl or walk over it! Never apply lacquer over wet waterbase basecoat, it will go all weird and holey underneath. I think of it like mixing water with oil, it doesn't work! You can sometimes just about get away with it with solvent, but it's not a good idea.
#34 In-a-mini
In-a-mini
  • 831 posts
  • Local Club: smag (southend mini action group)
Posted 03 March 2008 - 08:04 PM
yeah i like lechler clears they polish up really nice. i also use maxmayer i think its vertualy the same stuff i think the names are linked. water based is wierd stuff when you put it on i like the way it sometimes looks like the wrong colour then as it dries changes(fingers crossed lol). Looking good though
#35 Shifty
Shifty
  • 13,144 posts
  • Name: Sean
Posted 03 March 2008 - 08:24 PM
Thanks everyone for your support.
Its taken me about 4 hours so far but I am very happy with the results!!
Have just given it its 4th coat and it seems to have covered well.
I will give a coat of clear tommorrow and will post the results!!
So far so good
Thanks Again
Seamus
#36 Pepys
Pepys
  • 72 posts
  • Local Club: None
Posted 04 March 2008 - 09:36 AM
Just thought I'd chip in here and say good job. Someone's got to test out waterbased from home. I'm going to do it eventually and what you're doing is brilliant... if it works out >_<
#37 jonny d
jonny d
  • 1,148 posts
Posted 04 March 2008 - 04:06 PM
I also think you are very brave for attempting water base at home when everyone tells you what a pig it is, its looking brilliant wait till you get the clearcoat on
it will really shine then. Top ho to ya
#38 jack_marshall
jack_marshall
  • 2,540 posts
Posted 04 March 2008 - 05:20 PM
I reckon its working well for you cause your doing it with the garage door up.
Got plenty of air flow to dry it!
#39 Shifty
Shifty
  • 13,144 posts
  • Name: Sean
Posted 04 March 2008 - 06:38 PM
Ah so you noticed!!!
It was raining a bit outside so I didn't think there would be any harm!!
Anyway
Round 2
Left it overnight and it looked like this
Attached File  humpfrey_023.jpg   309.11K   96 downloads
Attached File  humpfrey_024.jpg   311.01K   70 downloads
It still looked good!!
No runs and by the finish I had used 3/4 of ltr paint
The matt dark finish showed up every imperfection!! DOH
I applied the clear coat mixed 2-1 with 10% thinners
And it looked like this
Attached File  humpfrey_025.jpg   323.89K   74 downloads
Attached File  humpfrey_026.jpg   317.06K   59 downloads
If you make out the finish through the fumes it looks ok!!
It Really shows the lack of fumes using the water based base coat compared to the 2 pack clear
I'm going to give it 30 mins to flash off and give it another coat
Thanks for all your support
Seamus
#40 In-a-mini
In-a-mini
  • 831 posts
Posted 04 March 2008 - 06:44 PM
Yeah great job.
someone posted that the gti is no good for waterbased that it needs to be a gti-w i dug out my paperwork for my gti and it stated that it is compliant for waterbased and solvent sae goes for my sri. So your gun should be fine.
#41 jack_marshall
jack_marshall
  • 2,540 posts
Posted 04 March 2008 - 06:50 PM
My bad!
I thought the 'W' was for water!
Anyway, finish looks great, should look spot on with abit of a polish!
Well done!
#42 Shifty
Shifty
  • 13,144 posts
  • Name: Sean
Posted 04 March 2008 - 07:05 PM
Ok then 2nd coat of clear
Attached File  humpfrey_026.jpg   317.06K   45 downloads
The clear looks a bit orange peely out of the gun but dries out quite nicely!!
Overall I'm over the moon with it.
How many coats of clear would you recommend?
Seamus
#43 In-a-mini
In-a-mini
  • 831 posts
I would have thought the same just thought i wouldcheck my ones never had a problem i just dont like chopping and changing between waterbased and solvent so i keep the gund specifically for that.
I normally go for 3 good coats so i have something to flat back with no worries if its a good finish sometimes leave it at two
Edited by In-a-mini, 04 March 2008 - 07:08 PM.
#44 Shifty
Shifty
  • 13,144 posts
  • Name: Sean
Posted 04 March 2008 - 07:58 PM
Ok then just put on the 3rd coat of clear
Took a pic of it beforehand
Attached File  humpfrey_027.jpg   307.71K   121 downloads
It looks pretty good even if I say so myself!!!
I'm off to get some fish and chips now, so will take some pics later
Seamus
#45 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 04 March 2008 - 08:42 PM
Looking good! 2 coats is the norm with lacquer. The "W" is GtiW does stand for water, the only difference between the W and the normal Gti is a slightly different fluid tip and air cap, which atomizes water base paint better. Either gun works fine, but the best is a 1.4 GTiW.
