Progress has been non-existant for the last few weeks due to other commitments, but I now find myself with some free time, so The restoration can continue.
Having placed the new floor section on, I managed to get it lined up square and started to weld it in place. I have seam welded all round the rear, and had started on the front, but then gave up as I wasnt happy with the way it was going, so will have a re-think there regarding the join between the new floor section and the existing bulkhead.
(apologies for the blurry pics, My hands are shaking like mad for some reason today. Ive probably caught Pakinsons or something cheery like that )
So today, I decided to crack on with the back end.
First up... the wheel arch was rotten in various places. Patchable, but would have looked shoddy, so I chopped the lot out.
I am keeping prices as low as possible for this car, so rather than buy a new panel, I attacked the donor shell and chopped its solid arch out roughly....
spent some time trimming it down, and ended up with an OE spec replacement part!
Drilled it and plug wlded into place....
I smoothed off the welds with a flap-wheel, then welded in a patch to finish the curve of the side panel (again, this was chopped from the donor shell)...
Towards the rear, I hacked he crusty old valence off and had a poke at the floor. Hmm, not ideal...
I also cut off the side skin lower section which was rotten...
Patched up the floor. Lots of card templates before committing to steel...
The finished off the skin...
The panel sections will need a wee skim of filler to smooth them off before paint.
Hopefully, I will get some time to continue tomorrow, The other side needs similar treatment, although I wont have to change the whole arch. I can then finish off the flange for the rear step.
Mojo is returning strongly. Having spent so long looking at it and making the holes bigger, to be actually putting it back together is wonderfull. The side I have done is now 100% solid and Im quite chuffed with the standards so far.yeah, its not the prettiest as is, but once the surface rust is removed and treated, the seams are covered in sealer and its painted, it will look fine.
