Things are ticking along nicely for a change. Mojo is high, and the end is in sight. Far away, mind - but within view!
Today I sorted out the other side a-pillar. Tidied up the nasty welding by whoever tried to deseam it, then welded on a new lip to take the joint cover.
Thats both sides done now. I have new joint covers, which needed a little re-bending to fit well, but thats done too.
Inside, for some reason, someone had chopped out the lower dash rail. They had welded in a bit of scaffolding tube in its place, which was hardy pretty.
tube removed...
I then chopped the dash rail from the donor shell back on the farm, and welded it into place...
Then onto the front valence - it was folded right under and again, someone had tried to deseam the front and hacked off the bumper lip, making a right chuff of it. So, I tidied up the valence, bent it back to shape, then chopped the lip from the donor shell and welded it on...
Still need to do a little panel beating there to smooth the curve of the valence out before I start paint prep, but that can wait for now.
The Gods of MIG were smiling on my SIP today, it was working a treat for a change, so I decided to finish off the last remaining big welding job, which was the outer sills. So, I took the van off the trestles and flipped it onto its side...
(not easy when you are on your own and in such a small space, but got there without mishap.
A new pair of sills had been included in the original sale. I hadnt really looked at them till now...
Cheap and nasty cover sills
Cover sills (also called oversills) are just that - they are designed to be welded straight over the top of the old rotten sills. They are a fair bit wider to allow you to weld to good metal on the floor away from the original rotten sills.
You can see their width here compared to the line you can see where the original sill was welded...
They are a complete bodge, that will get a mini through a MOT or two, but the rot is still under them and spreading rapidly.
The original sills were long gone, so I cut these things down along their length to convert them into standard sills. The fit isnt great, but its workable. Drilled all the holes required for the plug welds and thats one side ready...
I then treated and painted inside the sill section to prevent grot returning soon...
Then realised that I cant weld the sill on till the paint is dry. Past experience told me that this stuff is VERY flammable when still wet and welding near it before its dry results in big flames and nasty black smoke, so I left it for tonight. Should get the sill welded on tomorrow morning, then I can flip the shell the other way and attack the other side.
I was thinking today - I have the sills to finish, then a few wee bits and bobs to weld up...a couple of hours at most, then thats the shell finished and ready for stripping and paint prep!
Still got all the doors to do though, which might be tricky, but once they are done, I can get some paint on, then start with the mechanical refurbing and rebuild.
I will eat my boiler suit if its not finished for this summer!
