yes you have, i knew that but did not think it would be that bad with 1.25 spacers on....Yes they are wide but its the offset thats the problem!!
If you look at mini wheel and put a ruler across the front of the tyre, then measure the distance between the edge of the ruler and the nut holes, then do the same to a metro rim this distance will be less on the metro rim.
This means than when you bolt the wheel to the car the innermost edge of the wheel will be closer to the car than the the mini one. This will then foul on the suspension componants and hence the need for spacers!!
Phew!! I think i have explained that correctly!!
so should i just spend time looking for mini ones, is that best?
