First coat was applied with a compressor and spray gun, fine. Everything went smoothly. We let it dry for about 2hrs and then applied another coat. It appeared to go on fine until it started to dry, and then cracks appeared. Not very larger cracks, but still cracks, about 30mm in length. It also started to bubble around the window seal lip, along the top edge of where the wing is folded for the arch, and along the bonnet groove on the wings. The buuble are small in size.
We think it is a reaction, but don't know why. The places that it has occured dont make sense. Its cannot be lack of sanding as some of the places are on the new plates that dad made up. Its not the lacquer as this was sanded down easily to the previous primer.
We left it over night (last night) and went back to it this afternoon. We sanded down the bubble and cracks, then reapplied the primer to the offending parts. Within 5 mins of applying it, some of it came back, but not all of it Then, small cracks about 5mm in length appeared in different locations than before.
They all are either on lips, bottom of wing, wing groove for bonnet, window seal part, botton of roof rail. The wings are fine.
Some parts has started to flake as well, this is along the lip a the bottom of the wing.
james
p.s. also, we ruled out the cellulose thinner content of the primer applied as we bought some in a can to try, but no results.
Edited by james962, 27 March 2008 - 02:08 PM.
