Argghh Why Is The Primer Doing This?
#16
Posted 27 March 2008 - 10:07 PM
#17
Posted 27 March 2008 - 10:20 PM
still not said if he used panel wipe.
#18
Posted 27 March 2008 - 10:36 PM
when you say to flat it back, do you mean to remove the blisters and bubbles and to leave the rest that is visibily sound?
we have sanded back these areas before, and then re-primed it with a different primer, zinc primer. Some of it was alright, it appeared to cure the problem, but then some went like this:
The bit in the picture that peeled up was actually the primer applied yesterday. It peeled after we sanded down and re-primed an area that had blistered just under the headlight. This blister had appeared at least 20hours after the primer was applied. We rubbed the blister down smooth and re-primed. And within minutes, the peeling in the photo appeared.
You can also see in the photo that there is a small amount of peeling in the seam, and this occured with the peeling round the headlight.
Would you still recommend to smooth it down and apply 50:50 2K hardener and thinners or to sand down the lot and start again?
I'm abit worried about the rest that looks visibly sound and wonder if this will start to blister in the future.
#19
Posted 27 March 2008 - 10:37 PM
Edited by james962, 27 March 2008 - 10:38 PM.
#20
Posted 27 March 2008 - 10:39 PM
" i dont actually agree with any of the ideas above" what, not even mine?
Oh my apologies, didn't actually see your post in there! Oh whilst I remember, that waterbase paint you were asking about is called 420 topcoat, and is made my Lesonal.
#21
Posted 27 March 2008 - 10:42 PM
oh, and i haven't used any panel wipes. instead it was wet and dry'ed with plenty of water and detergent. Then rised and dryed off
What kind of detergent? could be caused by that. I hope you didn't use washing up liquid, it contains salt which will speed up any corrosion.
Going by the picture, the primer is not sticking. That could be caused by the existing coats melting underneath the primer, or water coming out of the seam. Did you blow out all the areas after you rinsed it off?
#22
Posted 27 March 2008 - 10:47 PM
All the areas were definately dry. We used the heat from a lamp
#23
Posted 27 March 2008 - 10:50 PM
Sorry to mis-lead, but instead of detergent we used soap
Hmm seeing as you're only getting problems around lips and seam edges, I think it's most likely to be water creeping out. It's very difficult to get rid of all the water when you've been wet flatting, even if you blow it out with compressed air. That's one of the reasons modern body shops on dry flat.
#24
Posted 27 March 2008 - 10:51 PM
when we say flat down, it means flatting the primer, not rubbing it all off.
any loose primer will come off when flatted, then wipe over with panel wipe and spray with bar coat, that will isolate all the primer underneath and stop any further reaction.
#25
Posted 27 March 2008 - 10:59 PM
I will have another crack at it at the weekend, and i will let you know how it goes.
thanks for your time, james
#26
Posted 28 March 2008 - 08:55 AM
Hope that may help ya
#27
Posted 28 March 2008 - 06:14 PM
Im worried you will manage to get it into paint only to have problems later down the line.
Personal opinion.
#28
Posted 28 March 2008 - 07:01 PM
I also agree with that, you will get problems further down the line if you try and paint over that paint after flatting it. my opinionPersonally Id stop cocking about trying to make the best out of a bad job and start again, doing it properly.
Personal opinion.
#29
Posted 28 March 2008 - 08:48 PM
#30
Posted 28 March 2008 - 09:29 PM
